toshiba u305-s2804 bios file
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello guys. im just looking for bios file
    for this laptop
    toshiba u305-s2804.
    tnx in advance guys...
  • angel-boy
    • 550
    Re: toshiba u305-s2804 bios file
    If you can , give us mainboard model / code
    • rickybucalan
      • May 2013
      • 322
      • philippines
      Originally posted by angel-boy
      if you can , give us mainboard model / code
      dabu1mb16e0 rev:e
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        here you go, try this
        but make backup
        Im Back... sort of...
        • deddyz
          • May 2016
          • indonesia
          makasih matur nuwun
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • maanee11
            Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
            by maanee11
            Hello Everyone,
            I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
            It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
            In the website, you can only see specs etc.
            I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
            11-08-2025, 04:08 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
          • HOHA
            BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
            by HOHA
            Hi can you help me
            I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
            IP3_TN16S_MB_V30_20210901A
            This is the old BIOS file, it is corrupted​...
            10-20-2024, 08:22 AM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
