Acer 4820TZG Black Screen - BIOS
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello Guys,
    I have this mobo : DA0ZQ1MB8D0 Rev. D
    PN : P604G32MNKS
    Black Sceen, No Usb, keyboard ....
    Light Reflow (Not used My Rework Station), still black ...
    Maybe it's time to test a New Bios Dump ?
    Anyone with a bios for this Mobo ?
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Acer 4820TZG Black Screen
    Please, i need a bios dump for this mobo.
    • ridamouh159
      • Nov 2014
      • 365
      • maroc
      try with this bios
      but use another ic bios better
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        vous devez laisser le circuit de bios a cotè et ne pas le vider
        et utiliser un autre circuit et le faire vider et ensuite le flasher
        toujours je travail avec cette methode
        c'est mieux pour garder le vrais fichier
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          i Hate Acer, i really don't understand how people can like this "Trash" ...
          I'm goging to reball the GPU, even if i already know the result.
          Changed ram, cpu (intel with graphics), tried 2 different bios and EC's ... same result, turns ON, but Nothing !
          Ohh I love Acer !
          @rida, merci mon frere.
          Vamos até ao fim tugas
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            After this new EC bios, Fan starts spinning crazy after 10 seconds.
            Wrong EC dump ?
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              for qunta zr7b Acer Aspire 4820TG
              • passete
                Living=Sharing
                • Jun 2015
                • 487
                • France
                This crazy, i started the lap after a few hours, and now it's working, but fan start to spin like crazy after 10 seconds !
                Wrong Bios or EC ?
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  @ala borbe as fixed my corrupted bios (main and ec).
                  Flashed main bios, pc booted and no more fan spinning crazy, turned off assembled the pc, turned on, and again black screen ....
                  Which bios cause the fan spinning fast, main or ec ?
                  EDIT: Removed the Top Screws (Under the keyboard) and it's working ...
                  • passete
                    Living=Sharing
                    • Jun 2015
                    • 487
                    • France
                    SOLVED, it was a screw on a wrong "hole".
                    I'm sharing the files used to fix this Netbook
                    1 - Unlocked Bios 1.25 (install directly from Windows)
                    2 - My Fixed main Bios by @ala borbe
                    3 - Ec Bios found on the web
                    Use those files if you mobo is the same, check first post
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      main bios was the problem
                      as for screws... put some tape over motherboard, your top cover (palm rest) touches and shorts motherboard
                      take that black tape or kepton tape and sick over board and you will be fine
                      Im Back... sort of...
                      • nassimhamdi
                        • Feb 2016
                        • 159
                        • algeria
                        thank you
                        • bajdik
                          • Aug 2015
                          • 68
                          • Czech Republic
                          For me, it doesnt work for 4820TG any of these files.
                          Works this for me only this one for 5820TG.
                          Type of the board: DA0ZQ1MB8F0 REV F
                          • amennone
                            Acer A315-24p-r2km , black screen. Bios
                            by amennone
                            Acer A315-24p-r2km Acer N23C3 snid: 32400005934 s/n NXKDEET00B3240003B3400 Main: IH5JM LA-M611P Rev: 1A
                            As per the title, the screen remains black. When the power button is pressed, the blue LED lights up, but the screen is black.
                            With an external monitor and HDMI output, there is no image. I loaded the following bins, same situation: ACER_A315_24P_IH5JM_LA_M611P_REV_1A_2022_08_22_WORKING_BIOS_100% IH5JM120.bin from this address https://www.badcaps.net/forum/troubl...a-m611p-rev-1a With the RT 809F programmer, I can't read the contents of the original XMC 25QU128CH1Q SPI, I get the...
                            07-31-2025, 04:19 PM
                          • mitchw
                            HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                            by mitchw
                            Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                            After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                            After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                            I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                            04-29-2025, 03:45 PM
                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-07-2024, 05:00 AM
                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 04:10 AM
                            Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                            This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 512GB SSD, NVIDIA RTX 3060,...
                            09-07-2024, 03:10 AM
