need a bios file of my hp probook 650 G1
  • mohammed mohan
    • Nov 2017
    • 198
    • z
    #41
    Re: need a bios file of my hp probook 650
    thank you
    Mohammed Mohan
    • almussafer
      • Jun 2019
      • 82
      • Iraq
      #42
      Here's your new file, try it and let me know the results.
      it works with an admin password requist
      • almussafer
        • Jun 2019
        • 82
        • Iraq
        #43
        Originally posted by Vesko356
        its work thanks
        • amirheidari681
          • Oct 2021
          • 43
          • iran
          #44
          hp ProBook 650 g1
          6050A2566301-MB-A03
          sn: JPA5035Z5G
          the board has all voltage's but no display with high speed fan
            SMDFlea commented
            Editing a comment
            Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
        • mmaewbsoft
          • Apr 2018
          • 65
          • yemen
          #45
          Hi everyone, im a new member, i hop to get your help about my probook 650 G1 :
          power botton blinking continously
          need bios fil
          part number of mainboard is 6050a2647201-mb--a02​
          • peste
            • Dec 2016
            • 13439
            • ROMANIA
            #46
            need bios fil
            post the S/N, post the original content of the bios chip, etc.
            • yooghi
              • Jan 2025
              • 4
              can someone remove the password of this Bin plz?
              • peste
                • Dec 2016
                • 13439
                • ROMANIA
                #48
                post S/N, full name and model, motherboard model, product number,,etc.
                post the original contents of the bios chip..not the update on the site, as far as I can see...what password should the update have??
                • yooghi
                  • Jan 2025
                  • 4
                  5CG4342LLP - HP Probook 650 G1 - Click image for larger version  Name:	image.png Views:	0 Size:	1.7 KB ID:	3556816 - D9S33AV -Click image for larger version  Name:	image.png Views:	0 Size:	2.7 KB ID:	3556817
                  Name SerialNumber Version
                  Default System BIOS 5CG4342LLP HPQOEM - 1​
                  Thanks for your Reply and i hope this will help
                  • yooghi
                    • Jan 2025
                    • 4
                    I don't have the BIOS password and I need help to remove it. If there's a way to reset or bypass it, or if you can provide a backup file that I can flash to solve the issue, that would be amazing.
                    Let me know if you need anything else from me.
                    Thanks a lot for your help!
                    • peste
                      • Dec 2016
                      • 13439
                      • ROMANIA
                      #51
                      I don't really understand, do you have a password on the bios or not?..if you do, and you want to remove it, post the original bios of the laptop..
                      • peste
                        • Dec 2016
                        • 13439
                        • ROMANIA
                        #52
                        you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
                        • manwald
                          • Sep 2019
                          • 7
                          Hey guys, I just got an old ProBook 650 G1 (F1P85ET#ABD) with the serial-no. 5CG55207ST.
                          Can anybody help me to unlock the BIOS, cause there's a password I don't know?
                            • 21692
                            RCUnlocker https://www.badcaps.net/forum/troubl...23#post1622423
                            You must make a backup of the bios chip using an SPI programmer
                            • manwald
                              • Sep 2019
                              • 7
                              Oh - no other chance using this SMC.bin file? I don't know how to use an SPI programmer :-(
                              • charif
                                • Feb 2016
                                • 28
                                • agad
                                #56
                                I have an HP ProBook 650 G1. I lost the original BIOS dump, so I flashed a BIOS file taken from another device of the same model. However, the laptop is now slow to boot, and displays a red warning message before startup.
                                I've attached the BIOS file I'm currently using. Any help to restore the correct or cleaned BIOS would be appreciated.
                                SN 5CG5071WH5
                                6050A2566301-MB-A04
                                • studdy05
                                  Bricked HP Probook 450 G7 Bios questions
                                  by studdy05
                                  Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                  Ive got...
                                  07-08-2025, 09:24 PM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
                                • m1ch43lzm
                                  Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                  by m1ch43lzm
                                  Hi everyone
                                  I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                  Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                  Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                  There's also an extra OTP Secu.R...
                                  09-06-2025, 05:47 PM
                                • Forest79
                                  by Forest79
                                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                  07-23-2023, 07:39 AM
                                • maanee11
                                  Help to get Lenovo BIOS bin file for Thinkpad T560
                                  by maanee11
                                  Hello Everyone,
                                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                  05-15-2022, 11:59 AM
