Es1-111 bios
  • alihomee
    • Dec 2012
    • 1598
    • malaysia
    Es1-111 bios
    need bios file for this model mobo num isA0ZHKMB60 REV:C
  • kazia
    • May 2015
    • 145
    • indonesia
    Re: Es1-111
    again..here..
    it's 1.8v vcc
    • alihomee
      • Dec 2012
      • 1598
      • malaysia
      Re: Es1-111
      thanks kazia but no display with ur file .i attach ori file also if somw body can help and full model is :ES1-111-C3NT
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Forest79
        by Forest79
        07-23-2023, 07:39 AM
