hi i need MACBOOK A1398 EMC 2673 bios m/b no 820-3332-A WITH VGA
hi i need MACBOOK A1398 EMC 2673 M/B 820-3332-A with VGA PLZ
Re: hi i need MACBOOK A1398 EMC 2673 M/B 820-3332-A with VGA PLZ
try this my friend:Attached Filesif you find these attachements useful please consider making a small donation to the site
Attached is the latest FW revision for this board with Clean ME (V426.0.0.0.0). Serial number is altered from original, so you will need to insert your own and update the Fsys block checksum to use. Will require a PRAM reset after installation.Attached Filesif you find these attachements useful please consider making a small donation to the site
Dummy serial number is C02J99ZZDKQ5 (length 12), you can find it on address 006904dcComment
Macbook Pro A1398 (820-3332-A
macbook stuck on apple logo with progress bar stuck too
attached backup file emc 2673Attached Filesif you find these attachements useful please consider making a small donation to the site
Apple MacBook Pro 15'' A1398 X435 051-00330 820-00138 Schematic & Board View
A1398 main board resistance measurements (user submitted no further details)...-
Channel: Schematics and Boardviews
10-01-2024, 06:58 AM -
by pippo_oneHi everyone, I have a MacBook a1398 emc2910 with an 820-00426A motherboard.
I have a short on the "PPBUS_G3H" line... I traced it to the "U7310" IC
FDMF6808N"
and indeed the IC is shorted between "Vin and VSWH."
On the motherboard, Vin to ground = open and it's OK.
VSWH to ground = about 5,50 / 7.50 Ohms.
With this measured value, can I safely replace this IC or is the CPU compromised?
Do you have any other suggestions?
Thanks for any help you can give me.07-20-2025, 03:35 AM -
by fishaHallo everyone, my A1398 do not charging the battery and the battery also do not bin recognized. I did all the reset work, SMC reset and all the other reset options but nothing helped. on the SMC at pin 2 (DCIN) there are 20,4V coming in. at pin 16 (BGATE) which goes to the Q7155 Gate there are only 11,43V. at the pin 1,2 and 3 on the Q7155 (Source) there are 12,23V. Cap C7126 is not shorted. As I understand, the gate voltege have to by higher then the source voltege for the gate to clous so the battery can be charging, am I right? can someone help me with this? I guess that manny models are working...
Apple MacBook Pro 15 Retina A1398 EMC2910 820-00426 Boardview...
10-26-2024, 04:08 AM -
Apple MacBook Pro Retina 15 A1398 820-3332-A Boardview...
10-22-2024, 04:31 AM -
- Loading...
