DAVM8NMB6D0 BIOS Dump needed!!!
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    I need a BIOS Dump for Dell Vostro 1014. My mobo is of DAVM8NMB6D0 REV : D series.
    I've flashed around three different dump but those are not campatible with this mobo. After flashing those only power LED blink one times. Please help me out bro.
    Thanks in advance.
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Re: BIOS Dump needed!!!
    can you one download the file from here please ?
    http://www.91xiu.com/thread-362378-1-1.html
    • kazia
      • May 2015
      • 145
      • indonesia
      backup and try..
      • subroto
        • Oct 2015
        • 230
        • Bangladesh
        Nothing to backup. The pc is damaged by customer during BIOS updating. But unfortunately this board is totally different. Mobo code is DAVM8NMB6D0 REV : D.
        Sometimes this mobo is known by VM8N.
        So I'm in stuck.
        Thanks for your help.
        • kazia
          • May 2015
          • 145
          • indonesia
          did you solved the problem
          • subroto
            • Oct 2015
            • 230
            • Bangladesh
            No bro. Still same. Just blink the power LED for once.
            • alas3376
              • Nov 2011
              • 382
              • BENIN
              here it is . dump from a working laptop
              • subroto
                • Oct 2015
                • 230
                • Bangladesh
                Thanks bro
                • Shamsi
                  • Oct 2015
                  • 31
                  • india
                  Thank you
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • TacticalFahrrad
                    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                    by TacticalFahrrad
                    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                    06-30-2025, 04:09 AM
                  • vinaypundith
                    Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                    by vinaypundith
                    I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                    So, I'm looking for a BIOS dump for this machine - a 16MB one....
                    08-03-2024, 12:32 PM
                  • James Maxwell
                    HP DM1-4000er Bios Dump needed
                    by James Maxwell
                    I badly need bios dump for HP DM1-4000er,
                    Model: HP DM1-4000er
                    Motherboard: DA0NM9MB6D0 REV.D
                    Product: QJ490EA#ACB
                    Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
                    10-28-2024, 05:38 PM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
