Lenovo G50-80 ACLU3/ACLU4 UMA NM-A362
  • O.Szilard
    • May 2019
    • 163
    • hungary
    #61
    Re: Lenovo G50-80 ACLU3/ACLU4 UMA NM-A362
    Originally posted by imranromi
    Try this.
    • ash91
      • Jun 2023
      • 34
      • SAUDI
      #62
      Try this.
      Work perfect
      • ravikishore
        • Jan 2020
        • 8
        • India
        #63
        Originally posted by tanveer
        Nm-a361 bios
        working perfect
        • francocariman
          • Nov 2020
          • 26
          • Argentina
          #64
          Hi, i need clean bios password please
            • 22125
            You MUST:
            • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
            • francocariman
              • Nov 2020
              • 26
              • Argentina
              #66
              Sorry...
              Lenovo g40-80
              Model name: 80E4
              SN: PF0F5931
              Board model number: ACLU3/ACLU4 UMA NM-A362 REV 1.0
              • hoaca388
                Badcaps
                • Jan 2022
                • 12420
                #67
                Sorry...
                Lenovo g40-80
                Model name: 80E4
                SN: PF0F5931
                G40-80 Laptop (Lenovo) - Type 80E4
                • faisalhabib
                  • Apr 2017
                  • 29
                  • Bangladesh
                  #68
                  Originally posted by DanielDacko
                  Re: Need Bios Lenovo G50-80 core I 3
                  I don't know which rule have you broken, but here you go.
                  THANKS 100% OK TESTED, FIRST DIPLAY COME
                  • Md Jibrail
                    • Mar 2023
                    • 21
                    • Saharsa
                    #69
                    Try this.
                    THANKS
                    • G_sene
                      Lenovo G40-80 ACLU3 ACLU4 NM A362 not charging
                      by G_sene
                      Hi, everyone.
                      I have this notebook that won't charge.
                      In Windows, the charger icon doesn't appear on the battery, but the charger turns on the notebook normally.
                      PU301:
                      Pin 5 (ACOK) - 5.97v
                      Pin 6 (ACDET) - 1.83v (should have 2.6)
                      Pin 16 (REGN) - 6v
                      PQ308 has no gate voltage, so it doesn't drive PQ309 low
                      With the battery connected, its voltage goes the reverse way to the jack, having 14v and not 20v:
                      PQ301 e PQ302
                      Pinos 1,2,3 14v
                      Pino 4 5v
                      Pinos 5,6,7,8 com 14v...
                      06-24-2025, 11:22 AM
                    • coasterghost
                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                      by coasterghost
                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                      System Hardware:
                      Processor: AMD Ryzen 7 PRO 5850U
                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                      09-08-2025, 10:46 PM
                    • paolotto
                      Lenovo 80e5 g50-80 ACLU3/ACLU4 NM-A361 rev.1.0 non si accende
                      by paolotto
                      hello I would like some help, my laptop Lenovo 80e5 g50-80 ACLU3 / ACLU4 NM-A361 rev.1.0 does not turn on. when I insert power the led4 flashes and the fan moves a little. I only found the diagram pdf 2014-09 -10 REV0.4. I would need for BoardViewer the version for my ACLU3 / ACLU4 NM-A361 rev.1 and also schematic pdf. Also doing measurements with the multimeter I find on the line + 1.35_VGS to ground 6.06 ohm. According to me too low.
                      am I facing a short circuit?
                      that line affects the rams soldered on the board
                      thank...
                      11-02-2020, 04:01 AM
                    • zakiyy
                      Lenovo G50-80 Not ON Charger (no led) but Battery OK (ACLU3/ACLU4 UMA NM-A362)
                      by zakiyy
                      Lenovo G50-80 (ACLU3/ACLU4 UMA NM-A362) Rev 1.0
                      With battery laptop work perfectly ! But with charger no power and not charging ! What can be the problem??
                      Direct from Charger PIN no connect to laptop: 20.v
                      PQ301 (4407A)
                      Drain: 20v - 19v 17v fluctuating
                      source: 19v - 18 -16v fluctuating
                      Gain: 19v - 18 -16v fluctuating
                      PQ302(4483a)
                      Drain: 2.5v then 5 then 10v then 11v sometimes18 then again 2.5v again and again..
                      04-25-2021, 07:43 AM
                      Lenovo 3000 Series Schematic
                      Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                      3000 C100 laptop with Braille keyboard
                      Lenovo 3000 C
                      C100, C200 - 15-inch XGA screen
                      Lenovo 3000 N
                      N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                      N500 - 15.4 inch screen.
                      Lenovo 3000 V
                      V100, V200 - 12.1-inch WXGA models
                      Lenovo 3000 G
                      G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                      10-04-2024, 06:05 AM
