Lenovo B490 (20205) LB49A Keyboard Problem
  • gps31
    • Oct 2012
    • 75
    • india
    1. Laptop Bios Password Locked
    2. Some one Programmed Bios to unlock ===> unlocked
    3. He Programmed with different version. Original: H9ET82IT but programmed is H9ET83WW.
    4. Problem Started here KB is working well within Bios but not working even in DOS (some keys working with different behaviors also none of Alpha Numeric keys working)
    5. Then reprogrammed again H9ET82IT the same Problem
    6. Tried different versions such as H9ET90TO the Same Problem
    the problem not only in internal keyboard also in external keyboard(USB)
    Board: Lenovo B490 LB49A MB 12208-1 48.4WZ01.011
    Can anyone provide Solution and Bios( Some China Sites such as Chinafix, vinafix have these bios but i have no credits to download from them)
    Note: the mentioned bios H9ET82IT & 90TO works in the same model other laptops
    Sorry for the lengthy description
  • gps31
    • Oct 2012
    • 75
    • india
    Re: Lenovo B490 (20205) LB49A Keyboard Problem
    Is no one having Bios for this
    Lenovo B490 LB49A MB 12208-1 48.4WZ01.011 ?
    • LP_tekh
      • Oct 2015
      • 95
      • Laos
      Back up bios and try
      • gps31
        • Oct 2012
        • 75
        • india
        This is for LA48 i need for
        • redappleguru
          • Oct 2012
          • 26
          • india
          This Bin File Have TN GOVT SPLASH on bios
          • cyberhack
            • Feb 2013
            • 466
            • Uk
            Here got this from china site
            • krithvii
              • Feb 2017
              • India
              bro is it the current version which supports WIFI or a mid old 2013 bios?????
              • Vivek84835
                • Jan 2019
                • India
                Anybody Give me bios bin for "Lenovo B490 LB49A MB 12208-1 48.4WZ02.011
                • madrali
                  lenovo e15 gen2 bios ? problem
                  by madrali
                  Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                  20TD-50S0KU00
                  Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                  I used Lenovo's SmartBeep decoder and it returned error 0284:
                  "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                  I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                  06-16-2025, 12:06 PM
                • AquaMan Ua
                  by AquaMan Ua
                  05-17-2025, 09:40 AM
                • jendkkd jeje
                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                  by jendkkd jeje
                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                  10-11-2024, 03:12 PM
                • konradx
                  Lenovo Thinkpad T15 Touchscreen problem bios
                  by konradx
                  i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
                  That is my DUMP.
                  My device:
                  SN: PF29Y4N6
                  1s20S7S2WF00PF29Y4N6
                  MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
                  09-06-2024, 01:33 AM
                • 1g0r
                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                  by 1g0r
                  First, the data in brief:
                  Manufacturer: Lenovo
                  Model: ThinkPad L15 G3 21C3-0016GE
                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                  IC Bios 1: MX77L25650F
                  IC Bios 2​: MX25L25673G
                  EC Chip: NPCX997KAABX
                  So far I've been a silent reader, but now I need your help
                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                  01-18-2025, 02:39 AM
