Lenovo B490 (20205) LB49A Keyboard Problem
  • gps31
    • Oct 2012
    • 75
    • india
    1. Laptop Bios Password Locked
    2. Some one Programmed Bios to unlock ===> unlocked
    3. He Programmed with different version. Original: H9ET82IT but programmed is H9ET83WW.
    4. Problem Started here KB is working well within Bios but not working even in DOS (some keys working with different behaviors also none of Alpha Numeric keys working)
    5. Then reprogrammed again H9ET82IT the same Problem
    6. Tried different versions such as H9ET90TO the Same Problem
    the problem not only in internal keyboard also in external keyboard(USB)
    Board: Lenovo B490 LB49A MB 12208-1 48.4WZ01.011
    Can anyone provide Solution and Bios( Some China Sites such as Chinafix, vinafix have these bios but i have no credits to download from them)
    Note: the mentioned bios H9ET82IT & 90TO works in the same model other laptops
    Sorry for the lengthy description
  • gps31
    • Oct 2012
    • 75
    • india
    Re: Lenovo B490 (20205) LB49A Keyboard Problem
    Is no one having Bios for this
    Lenovo B490 LB49A MB 12208-1 48.4WZ01.011 ?
    • LP_tekh
      • Oct 2015
      • 95
      • Laos
      Back up bios and try
      • gps31
        • Oct 2012
        • 75
        • india
        This is for LA48 i need for
        • redappleguru
          • Oct 2012
          • 27
          • india
          This Bin File Have TN GOVT SPLASH on bios
          • cyberhack
            • Feb 2013
            • 466
            • Uk
            Here got this from china site
            • krithvii
              • Feb 2017
              • India
              bro is it the current version which supports WIFI or a mid old 2013 bios?????
              • Vivek84835
                • Jan 2019
                • India
                Anybody Give me bios bin for "Lenovo B490 LB49A MB 12208-1 48.4WZ02.011
                • lucaszmn
                  by lucaszmn
                  Problem:
                  Initial Findings:
                  • I concluded that the
                  08-12-2025, 03:01 PM
                • c.daniel
                  Lenovo V310-15IKB weird bios problem...
                  by c.daniel
                  Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                  sn LR09493E
                  MB DAOLV6MB6F0 REV. F
                  The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                  Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                  Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                  08-22-2025, 05:39 AM
                • madrali
                  lenovo e15 gen2 bios ? problem
                  by madrali
                  Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                  20TD-50S0KU00
                  Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                  I used Lenovo's SmartBeep decoder and it returned error 0284:
                  "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                  I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                  06-16-2025, 12:06 PM
                • MaxonDomkrat
                  Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                  by MaxonDomkrat
                  Hi everyone.
                  I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                  07-30-2025, 01:27 PM
                • AquaMan Ua
                  Problem with PANASONIC CF53 laptop after changing BIOS settings
                  by AquaMan Ua
                  Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                  05-17-2025, 09:40 AM
