CHICAGO_BR_HPC MV_MB_V1 Bios
+ More Options
Posts
  • pcnetch
    • Aug 2013
    • 125
    • Sri Lanka
    CHICAGO_BR_HPC MV_MB_V1 Working BIOS dump (AMD Soldered Processor)
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: CHICAGO_BR_HPC MV_MB_V1 Bios
    • kadi144
      • Aug 2015
      • 690
      • algerie
      thank you
      • idhea
        • Nov 2016
        • indonesia
        Its working, thank you bro
        • syml taufiq
          • Jun 2015
          • 14
          • indonesia
          thanks
          • fharlock999
            • Nov 2017
            • 61
            • Chile
            thanks
            • Djanoe
              • Apr 2019
              • 7
              • Indonesia
              • 3xdan
                • 5
                • romania
                • Andyservo
                  • Jun 2013
                  • 152
                  • Indonesia
                  thank you
                  • percoco2000
                    • Feb 2019
                    • Italy
                    Thank you. Saved my HP635
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • grimacelord
                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                      by grimacelord
                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                      Motherboard model number: DA0PAMB46A1 REV: A
                      Secondary motherboard model number: 0PAB
                      SKU: 685K4UA
                      Serial number is: 5CD3223BJP
                      Recently reflashed this laptop with latest BIOS and once...
                      05-07-2024, 08:06 AM
                    • DynaxSC
                      Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                      by DynaxSC
                      I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                      It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                      I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                      11-06-2022, 05:22 PM
                    • TacticalFahrrad
                      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                      by TacticalFahrrad
                      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                      06-30-2025, 04:09 AM
