Hp g62 da0ax1mb6h1 Working dump
  • imranromi
    • Jan 2015
    • 1291
    • Pakistan
    Working dump.
  • LP_tekh
    • Oct 2015
    • 95
    • Laos
    Re: Hp g62 da0ax1mb6h1
    Thanks for sharing!
    • kadi144
      • Aug 2015
      • 690
      • algerie
      many thanks .....
      • 580shahzad
        • Jan 2012
        • 65
        • PAKISTAN
        Re: Dell 1564
        thanx
        • harshana
          • Aug 2022
          • 216
          • Sri Lanka
          Looking for HP G62 Bios - DA0AX1MB6H1 REV H
          Motherboard: DA0AX1MB6H1 REV H
          anybody own bios files for this laptop. I tried one from the internet but still no power.
          Can I get tested one to make sure please
          • qayyum786
            • Aug 2018
            • 1959
            • INDIA
            Re: Looking for HP G62 Bios - DA0AX1MB6H1 REV H
            post your backup
            • harshana
              • Aug 2022
              • 216
              • Sri Lanka
              Originally posted by qayyum786
              post your backup
              Here are them. Both EC and Main.
              • hoaca388
                Badcaps
                • Jan 2022
                • 12441
                HP G62-300 Notebook PC series
                • harshana
                  • Aug 2022
                  • 216
                  • Sri Lanka
                  Thanks. Will check and let you know
                  • harshana
                    • Aug 2022
                    • 216
                    • Sri Lanka
                    this only has main bios file I guess. I need both Main and EC bios. Any luck???
                    • harshana
                      • Aug 2022
                      • 216
                      • Sri Lanka
                      Re: Hp g62 da0ax1mb6h1 Working dump
                      Flashed another one and it also failed. cant we fix old bios
                      • FedorovV
                        MSI Alpha 15 B5EEK-237XRU Need BIOS working DUMP from a laptop, not from the site.
                        by FedorovV
                        MSI Alpha 15 B5EEK-237XRU SN:K2209N0193161
                        Came without initialization. Before that, it was not under repair. With BIOS from the official website, there is a start Ok, after a while the fans gain speed and the laptop turns off.
                        The cooling system is cleaned, the contact spot is good.
                        I need a working dump from laptop to check.
                        This is an original, not working dump....
                        03-10-2024, 07:26 PM
                      • bobrino
                        Need working ec dump Lenovo YOGA 730-15ikb (la-f661p)
                        by bobrino
                        Hi, guys. Maybe, anybody has working dump ene kb9022q d for this laptop (not from update)? Motherboard la-f661p. Don't working keyboard and tauchpad. I want to downgrade bios ec version. Many thanks
                        02-08-2023, 09:21 AM
                      • Bimad99
                        HP ELITEDESK 705 G2 BASE MODEL SFF - NEED WORKING DUMP
                        by Bimad99
                        i need a working bios for an HP elitedesk 705 g2 base model sff machine, the problem is the machine turns on but there is no display.
                        SERIAL NUMBER : CZC615CDTY
                        BOARD MODEL NUMBER : 798073-001 REV 0C
                        THE BACKUP DUMPS ARE ATTACHED DOWN BELOW.
                        And this model has three SPI FLASH ICs, two 64mb (U19 and U68) and one 8mb (U11), i need clarification which one is the main bios chip ???!!!...
                        05-19-2024, 04:51 AM
                      • TyMercer
                        Can I flash a working BIOS from one computer to another of the same make, model, etc?
                        by TyMercer
                        Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                        11-13-2025, 09:39 PM
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
