Acer V5-552P Bios dump needed
  • rs232killer
    • Feb 2015
    • 89
    • Portugal
    Hi
    Original file in attach, the machine have a weird behaviour, well its a machine i know.
    doesnt let install OS and gives a beautiful BSOD on the windows setup
    btw its AMD wich its 90% of the problem
    Tks in advance
    Regards
    RS
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Acer V5-552P Bios dump needed
    can you please try this
    Im Back... sort of...
    • rs232killer
      • Feb 2015
      • 89
      • Portugal
      Hi
      tks for the bios , its doing the same thing , i hate amd machines crappy chips , its probably bad chipset or one of the ram chips soldered on board ...
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        yes... you can reflow to confirm
        • rs232killer
          • Feb 2015
          • 89
          • Portugal
          first will give price for new mb then lets see the outcome of that
          Tks anyway for the support as always you are extremly helpfull with everyone
          regards
          RS
          • dmurgas
            • Oct 2016
            • El Salvador
            gracias.. mercy, tks
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
              BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
            • James Maxwell
              HP DM1-4000er Bios Dump needed
              by James Maxwell
              I badly need bios dump for HP DM1-4000er,
              Model: HP DM1-4000er
              Motherboard: DA0NM9MB6D0 REV.D
              Product: QJ490EA#ACB
              Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
              10-28-2024, 05:38 PM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • NecroFlex
              Acer Aspire 1 A115-32-C28P BIOS needed please
              by NecroFlex
              I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
              I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
              I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
              02-11-2025, 08:51 AM
