Lenovo ThinkPad Edge E531 BIOS
  • TossDon
    AKA Masood
    • Jun 2013
    • 26
    Hi guys,
    I have a Lenovo Edge E531, MB Part# 04Y1299, won't accept any AC adapter, won't charge the battery and just shuts down after flashing the message that the AC adapter is not genuine( which is), this started after upgrading the BIOS.
    Any one has the BIOS files, EC and Main? or any ideas?
  • rs232killer
    • Feb 2015
    • 89
    • Portugal
    Re: Lenovo ThinkPad Edge E531 BIOS
    Hi
    it can coincidence, do you have another AC adapter to test ?
    The AC have a small eprom that says to laptop power and model so it can be damaged on the process or miss writed / bad match from bios
    regards
    RS
    • TossDon
      AKA Masood
      • Jun 2013
      • 26
      Yes, I have 2 adapters, both were tested on other Lenovo's OK, one was actually being used to charge it until the BIOS update, I know the 1 wire protocol to check the ID but I think it is the BIOS is messed up. Thanks though.
      • TossDon
        AKA Masood
        • Jun 2013
        • 26
        Hi Guys,
        Any one have the BIOS dump of Lenovo edge E531, MB: VILE2 Compal NM-A044 Rev: 1.0
        EC and main please, thanks for your help.
        • AlikDiana
          • Feb 2016
          • China
          Did you solved your problem now? Did you try to reinstall the bios drivers?
          lenovo driver | driver doctor
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • 1g0r
            Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
            by 1g0r
            First, the data in brief:
            Manufacturer: Lenovo
            Model: ThinkPad L15 G3 21C3-0016GE
            motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
            IC Bios 1: MX77L25650F
            IC Bios 2​: MX25L25673G
            EC Chip: NPCX997KAABX
            So far I've been a silent reader, but now I need your help
            I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
            I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
            The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
            01-18-2025, 02:39 AM
          • MaxonDomkrat
            Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
            by MaxonDomkrat
            Hi everyone.
            I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
            07-30-2025, 01:27 PM
          • akwky
            by akwky
            Hi!
            04-14-2025, 01:56 PM
