Bios file longer than chip
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi There
    So many time i need to program a bios chip by chip programmer (I'm Using a Batronics Bagero), but i find the bios files longer than the bios chip capacity.
    Just now i've a problem with a Dell Vostro 3460. I've found the bios file from Dell, but the file .bin (in this case is a Cab extension file) is bigger than the bios chip.
    Anyone can help me on this?
    Thanks and best regards
    Luca
    • 30977
    Re: Bios file longer than chip
    post it here
    • naeemshahzad
      • Jan 2015
      • 129
      • uae
      Hi if your motherboard graphic chip is nvidia than try this .
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        Try this
        • nbanti
          • 56
          You have to find Bios dump file. and you can program the bios chip. and after that update bios in Windows.
          • testaccgta
            Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
            by testaccgta
            Hi, everyone!
            I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
            I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
            09-01-2024, 08:24 PM
          • Azurain
            Elitebook 840 G5 Bios Chip Soldering Question
            by Azurain
            I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
            Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
            04-14-2023, 06:58 PM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • Zentech
            Unable to Write Bios File to SOCIC 25Q128FVPQ Chip
            by Zentech
            bios chip: 25Q128FVPQ
            MB SN: 6050A2822301-MB-A01
            when I first got this laptop the bios was locked, I unsoldered and unlocked the bios. the problem is that I lifted a couple of pads from the MB. So I couldn't use the WSON chip that comes with the board, so I got an equivalent bios chip SOCIC 8pin. The problem is that I'm trying to write the file (original) to the chip and it will not program it. I'm using NeoProgrammer.
            Here's the error
            Code:
            Current programmer: CH341
            15:29:00
            Programming memory(verifying)...
            Verification error on address: 00133000
            03-10-2022, 02:39 PM
          • ed1i
            Dell Inspion 7610 bios chip
            by ed1i
            Hello, I'm looking for bios chip on the motherboard on Dell Inspiron 7610. Server tag: CS4MDL3. I found on the back on the motherboard chip named: Winbond 25Q256JVEQ. Is it the right bios chip for this motherboard? I need to flash new bios on the chip, because it's stuck in infinity reboots. Is it possible this chip to be read AsProgrammer 25Q256JV option and ch341a programmer?...
            01-16-2025, 02:14 PM
