Asus X551MA bios dump needed
  • rs232killer
    • Feb 2015
    • 89
    • Portugal
    Hi
    need Asus X551M bios dump
    mb X551MA rev 2
    the bios chip is not recognized by programmer so i dont have original one.
    thanks in advance
  • marius_gsm
    • Apr 2015
    • Romania
    Re: Asus X551MA bios dump needed
    HELLO,
    Try this bios dump and post results.
    Thanks.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      try this
      Im Back... sort of...
      • sancheti81
        • May 2014
        • 191
        • India
        thanks ala_borbe
        • maurovalero
          • Sep 2018
          • 69
          • colombia
          hi, bios dump works perfectly, but to program the bios i was to uncheky "check id" and "verify after" muchas gracias
          • Macias
            • Nov 2019
            • 83
            • Ecuador
            • md rubel
              • Mar 2018
              • 6
              • bangladesh
              pls ec bios pls pls
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • vinaypundith
                Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                by vinaypundith
                I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                So, I'm looking for a BIOS dump for this machine - a 16MB one....
                08-03-2024, 12:32 PM
