HP DV6-6119TX Bios need
  • gps31
    • Oct 2012
    • 75
    • india
    I need bios dump for
    HP DV6-6119TX
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP DV6-6119TX Bios need
    backup old bios and try this
    Im Back... sort of...
    • gps31
      • Oct 2012
      • 75
      • india
      EC Dump
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        post old ec or motherboard code and i will try to help
        • gps31
          • Oct 2012
          • 75
          • india
          Hello Mr. ala_borbe
          Here attached actual dump from dv6-6119tx
          Problem: Caps Lock Blink code 1 ( CPU not functional)
          Steps: Cpu socket cleaned and cpu changed also reflowed both Intel and ATI Chips
          Result: the same error
          So i m trying flashing bios
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            no ec bios in web update available, only main
            but here is same version you had, so it must match your current ec
            if still the same, probably not bios related problem
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • cekcons
              g1 assassin Rev 1 bios dump - main and backup needed
              by cekcons
              main and backup ic dead so i cant post corrupt bios cause its 01 all over.
              thanks
              01-23-2024, 03:26 AM
            • grimacelord
              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
              by grimacelord
              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
              Motherboard model number: DA0PAMB46A1 REV: A
              Secondary motherboard model number: 0PAB
              SKU: 685K4UA
              Serial number is: 5CD3223BJP
              Recently reflashed this laptop with latest BIOS and once...
              05-07-2024, 08:06 AM
            • DynaxSC
              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
              by DynaxSC
              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
              11-06-2022, 05:22 PM
