Asus X453M bios dump needed
  • kazia
    • May 2015
    • 145
    • indonesia
    it's asus x453ma mainboard, light on and fan spinning. but no display at all.
    anybody has this bios?
    attached the original bios
    thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus X453M bios dump needed
    try this
    Im Back... sort of...
    • kazia
      • May 2015
      • 145
      • indonesia
      Thanks my friend, it's work..
      • shahrammohebbi
        • Jan 2015
        • 13
        • iran
        thanks a lot
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          hi, you say it works but when i use it even stanby doesnt work ! and the dump i have, there is a password. Are there somebody can provide a working dump please..?
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            have you tried dump from my post?
            if it does not, post your dump please
            • mukti
              • Jun 2014
              • 11
              • indonesia
              thank a lot
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                it works ,
                Many thanks
                • alex_valle
                  • Apr 2017
                  • chile
                  muchas gracias, desde chile
                  • zurvanielle
                    • Feb 2017
                    • 137
                    • Philippines
                    bios file work.... tnx for sharing....^_~
                    • Pascal Komlassan
                      • Jan 2017
                      • 809
                      • TOGO
                      Originally posted by ala_borbe
                      try this
                      thank's bro
                      • djharold
                        • Aug 2015
                        • 241
                        • COLOMBIA
                        I need x453sa rev 2.0 bios dump please
                        • djharold
                          • Aug 2015
                          • 241
                          • COLOMBIA
                          thanks for this
                          • kus234
                            • Jul 2015
                            • 35
                            • java
                            thx bos
                            • djharold
                              • Aug 2015
                              • 241
                              • COLOMBIA
                              thanks
                              • boingboing
                                • May 2016
                                • England
                                Working fine. Thankyou. This is version 214.
                                • jairus2005
                                  • May 2019
                                  • Philippines
                                  Try this
                                  • Alkamlay
                                    • Sep 2013
                                    • Indonesia
                                    Thanks bro..
                                    • aljhan17
                                      • Nov 2014
                                      • philippines
                                      how about if after flashing the serial number was gone.. how can i rrwtite the serial.. thanks in advance
                                      • rcn29
                                        • Jul 2020
                                        • 6
                                        • Philippines
                                        Originally posted by jairus2005
                                        Try this
                                        will try this. thanks
                                        • kodox
                                          Asus ExpertBook B1400CB Bios Dump Needed
                                          by kodox
                                          need original bios dump, original bios has flashed by other technician before me.
                                          attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                          unit info:
                                          Model: Asus ExpertBook B1400CBA-0711A1235U
                                          S/N: R6NXNZ006657238
                                          CN: 7F6F
                                          Mainboard Code: B1500CBA R2.1...
                                          Yesterday, 12:20 PM
                                        • DynaxSC
                                          by DynaxSC
                                          06-14-2024, 03:49 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • TacticalFahrrad
                                          [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                          by TacticalFahrrad
                                          I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                          06-30-2025, 04:09 AM
