hp pavilion touchsmart 11 bios dump
  • mangtomas
    • Jun 2014
    • 63
    • philippines
    need bios dump of hp pavilion touchsmart 11 MB is zkt11 la-a521p,thanks
  • niku1982
    • Jan 2016
    • albania
    Re: hp pavilion touchsmart 11 bios dump
    hi i need bios dump for hp 15-n020el.thanx
    • nimmay
      • Dec 2015
      • 82
      • Pakistan
      hi all friends
      HP Envy 17-J Intel Laptop Motherboard s989 720268-501 schematic diagram need
      • on/off
        • Oct 2016
        • 333
        • Indonesia
        Originally posted by nimmay
        hi all friends
        only found on paysite:
        https://vinafix.vn/threads/17cru-605...a2549601.7918/
        • nimmay
          • Dec 2015
          • 82
          • Pakistan
          hi friends:
          i need hp pavilion 15-ab292nr (touch) bios
          MODEL:X1FD
          DAX1FDMB6F0 Rev:F
          need bios Dump
          thanks
          • alihomee
            • Dec 2012
            • 1598
            • malaysia
            try this
            • olfelys
              HP Pavilion 500-560nf (Memphis-S, SSID 2B2C) – BIOS dump request (8 MB .bin)
              by olfelys
              Request: Looking for a BIOS dump for HP Pavilion 500-560nf (SKU L1V04EA), motherboard Pegatron Memphis-S / SSID 2B2C.
              My board enters jumper recovery mode but no BIOS files are available from HP anymore.
              I need the full 8 MB BIOS dump (.bin) (with .sig/.s12 if possible), or at least a clean dump I can flash with CH341A.
              Already checked HP support & Win-Raid packages (they only contain Intel ME firmware, not the BIOS).
              post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it,...
              09-05-2025, 12:38 AM
            • Ahari
              by Ahari
              I...
              08-13-2025, 06:12 AM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • haitham sharabati
              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
              by haitham sharabati
              Hello engineers 😀,
              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
              💀 Problem:😅
              - Device shows “Administrator Password”...
              08-07-2025, 04:54 AM
