Need Dell vostro 1015 bios Urgent
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    Hy friend
    my laptop num lock, and scroll lock ,led is flashing ........its may be bios problem please help
    motherborad part no : davm9nmb6do Rev : D
  • Ashwani jangir
    • May 2015
    • 5
    • india
    Re: Need Dell vostro 1015 bios Urgent
    there are two bios.....try it
    • razu
      • Jan 2015
      • 218
      • Bangladesh
      Re: Need Dell vostro 1015 bios Urgent solved
      Thanks for reply But its not have bios problem. Its problem is Two tiny transistors (k72) problem (by corrosion) I replace those Pnp Transistors and its work fine.... Its solvedd
      Wish u good luck my all forum friends
      • razu
        • Jan 2015
        • 218
        • Bangladesh
        here is original ok bios
        • bayuseto
          • Mar 2013
          • 13
          • Indonesia
          • ChetanSethi
            • Oct 2015
            • 11
            • India
            DAVM9NMB6D0 battery charging but no show plugged in any solution
            • sachinwagh665
              • 5
              • India
              dell vostro 1015 screen backlight not work
              • maximuz
                • 20
                • INDONESIA
                Hp g4 1311tu bios needed
                • Nwokem ugochukwu
                  • Jan 2021
                  • 9
                  • Nigeria
                  Please guys help me with this file Dell DAVM9MMB6G0 REV :G
                  • grafleri
                    • Apr 2021
                    • Ukraine
                    Hi. In attachment file for Dell. But I didn't see work my MB.
                    • grafleri
                      • Apr 2021
                      • Ukraine
                      Hi. Thanks.
                      • mevlut_316
                        • Oct 2014
                        • 18
                        • TÜRKİYE
                        Thank you
                        • zenius
                          by zenius
                          12-08-2024, 06:13 AM
                        • 417731
                          BIOS needed for Dell Vostro 3405
                          by 417731
                          Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                          Model: Dell Vostro 3405
                          Tag:F0B1YF3
                          CPU:Ryzen 3500U
                          Thanks in advance
                          07-06-2025, 06:48 PM
                        • mikeybass
                          by mikeybass
                          04-23-2025, 04:30 PM
                        • capoplays
                          Help with BIOS update on Dell G15 5515 after chip replacement
                          by capoplays
                          Hey everyone,
                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                          When I check the BIOS using the F12 menu Flash...
                          10-24-2025, 06:53 AM
                        • evolpe
                          BIOS DELL VOSTRO 3500 (GDI5A LA-K033P)
                          by evolpe
                          Hi guys, can anyone help me with this bios? It needs to be cleaned.
                          Motheboard: GDI5A LA-K033P REV 1.0 (A00)
                          Service TAG: BNV5GD3
                          I've attached the two BIOS (16MB and 8MB). The laptop turns on but only displays a backlight. I tried another BIOS and it works fine, but I can't exit manufacturing mode. Thanks to anyone who can help me....
                          11-11-2025, 02:16 PM
