Replace bios chip on HP CQ71 Mobo
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    I have here a CQ71 mobo with no power, I read some threads about this problem, most of the time is bios related.
    Now, the mobo bios chip is a cFeon F80-75HCP, but my bios programmer (CH341A) doesn't work with this chip.
    Can I replace this chip with a winbond SPI 25 ?
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: Replace bios chip on HP CQ71 Mobo
    You can replace the bios chip with other chip with the same size and it will work, and for your programmer you have to buy adapter that fit your chip and you good to go.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Size is the same as the winbond, it's with the programmer that I have the problem.
      The CH341A software only accepts 25XX and 24XX chips, I don't see any cFeon F80-75HCP on the list.
      • PlusCom
        • May 2013
        • 50
        • Greece
        You will not find it with that name your chip is EN25F80 try with this one.
        • atsio
          • Oct 2013
          • 819
          • Greece
          You have to search for 25 spi flash - eon - en25f80
          • passete
            Living=Sharing
            • Jun 2015
            • 487
            • France
            Thank you guys, now I just need to find the bios file and flash it ?
            or I'm stuck with the tattoo thing ?
            • passete
              Living=Sharing
              • Jun 2015
              • 487
              • France
              wow, it worked with this file : https://www.badcaps.net/forum/showth...139#post575139
              YEAH, mobo now is giving lights, I guess that now I need to enter the SN !
              is there a little guide or tutorial for this ?
              • atsio
                • Oct 2013
                • 819
                • Greece
                Tattoo has nothing to do with laptop not starting
                • passete
                  Living=Sharing
                  • Jun 2015
                  • 487
                  • France
                  I know, thanks !
                  Box is now starting (after flashing bios chip), fan is running and leds are ON, before there was NOTHING.
                  But I think that I'm stuck now, cause I don't have the keyboard neither the internal screen.
                  I know that is mobo don't give bios access to external display.
                  I see the Cap's Lock led blinking (led is on mobo, not on kb) plus 2 others leds flashing at same time.
                  • fddizon
                    • Sep 2011
                    • 555
                    • Philippines
                    count the blinks before the pause search in hp website blink error codes
                    • passete
                      Living=Sharing
                      • Jun 2015
                      • 487
                      • France
                      The caps lock motherboard led blinks 3 times.
                      Ok, swapped memory now I need to tatoo
                      • ala_borbe
                        aka Donald
                        • 1625
                        • Malta
                        post exact model of laptop (cq71-xxxx) and exact model of motherboard 6050XXXXXX...
                        and then post nonworking bios here
                        Im Back... sort of...
                        • passete
                          Living=Sharing
                          • Jun 2015
                          • 487
                          • France
                          OK, I have succeed to tattoo the cq71 mobo (I think), but now either LAN or WLAN can't connect, even with a fresh install !
                          Is this related with a bad tattoo ?
                          Thank you
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            dono what tattoo is...
                            anyways it can be bios, it can be cold joint on chipset (reflow or reball to be sure), and also you need HP Launch Button app to turn wifi on or off... also, there is button near power button for that if i recall correctly
                            • passete
                              Living=Sharing
                              • Jun 2015
                              • 487
                              • France
                              By tattoo I mean enter the values like SN, PCID, etc that get erased once you flash the bios.
                              I notice that the LAN as not a Mac address, only 00:00 zeros ...
                              EDIT: SOLVED, wrote to eeprom a mac address from a old pci card
                              • ala_borbe
                                aka Donald
                                • 1625
                                • Malta
                                well i can take that data from dump and paste it to new bios and then you flash it and we will see
                                • passete
                                  Living=Sharing
                                  • Jun 2015
                                  • 487
                                  • France
                                  Thank you buddy, I just entered a old mac address on the bios and now Lan is working.
                                  Thanks for your time.
                                  • DynaxSC
                                    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                    by DynaxSC
                                    Hi
                                    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                    08-04-2025, 12:20 PM
                                    Common SPI bios chip programming Questions and Answers
                                    by SMDFlea
                                    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                                    A: If you can`t read from it how do you expect to write to it ?.
                                    Q: Why is my bios chip unreadable ?.
                                    A: The programmer is faulty or has a worn or broken zif socket.
                                    The USB cable is frayed,connector pins worn or some other physical damage.
                                    Not enough amperage or voltage to power the programmer properly.
                                    Bad...
                                    09-02-2021, 04:40 PM
                                  • JoWed
                                    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                                    by JoWed
                                    Hello Community,
                                    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                                    07-01-2025, 09:32 AM
                                  • hotcrossedbuns999
                                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                    by hotcrossedbuns999
                                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                    3. I could only locate two chips that look like bios chips. Could someone verify this
                                    01-03-2025, 12:32 PM
                                  • inck243
                                    Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                    by inck243
                                    Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                    The BIOS...
                                    07-25-2024, 09:17 AM
