HP Pavilion G6-2262ss amd Bios Dump Needed
  • torrox30
    • Jul 2015
    • 3
    • Spain
    Hi!! My laptop HP pavilion g6-2262ss amd (Spanish) has a problem. One day i started the laptop and the Caps Lock lights 2 times, over and over again. The screen is black. I think the bios is corrupt, I have a friend with a programmer, and he said me that we need a bios dump file to rewrite the bios of the laptop. Could anybody help me? Thanks a lot in advance!!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP Pavilion G6-2262ss amd Bios Dump Needed
    first backup old bios
    this model has two possible motherboards, so two bios provided
    those are virgin bios, contains no serial or model number so it needs to be fixed with NBDmiFit utill by HP (or post your old non working bios here so i may fix dump for you)
    Im Back... sort of...
    • torrox30
      • Jul 2015
      • 3
      • Spain
      Great!! Fantastic!! Thanks a lot!!!! I'm going to try to backup the bios and i post here ok? Thank you very much!!!
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • TacticalFahrrad
        [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
        by TacticalFahrrad
        I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
        BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
        I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
        06-30-2025, 04:09 AM
      • vinaypundith
        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
        by vinaypundith
        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
        So, I'm looking for a BIOS dump for this machine - a 16MB one....
        08-03-2024, 12:32 PM
      • James Maxwell
        HP DM1-4000er Bios Dump needed
        by James Maxwell
        I badly need bios dump for HP DM1-4000er,
        Model: HP DM1-4000er
        Motherboard: DA0NM9MB6D0 REV.D
        Product: QJ490EA#ACB
        Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
        10-28-2024, 05:38 PM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
