Flash bios
  • Esse
    • Apr 2014
    • 317
    • TOGO
    Flash bios
    Please can somebody tell step by step how to flash bios and what is a dump file
  • Mario
    • Sep 2007
    • 64
    Re: Flash bios
    I use a tl866cs universal programmer. They read quite a lot of chips. Ch341 is cheaper and can read most bios chips if you only want to program bios.
    I use sop to dip adapters desolder bios. Put it in the programmer and back it up onto the computer. I select tbe right chip and there is a dropdown menu to read the contents. It just reads the contents of the chip and thats a bios dump.
    I would then open the new bios file and click program to write to the chip. Solder it back to the main board and it should hopefully work.
    I can try taking photos of the process if you want. Let me know
    Dump file is the output contents of what was read from the bios chip
    Hope it helps. My English isn't to great. I hope readable....
    • Esse
      • Apr 2014
      • 317
      • TOGO
      Re: Flash bios
      It can very clear for me if you can illustrat with photo.thanks
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        Re: Flash bios
        Can someone explain differance betwwen BIOS and EC, and how to find EC on board?
        ...the quieter you become the more you are able to hear...
        • Esse
          • Apr 2014
          • 317
          • TOGO
          Re: Flash bios
          What is EC?
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            Re: Flash bios
            Embedded controler
            • haitham sharabati
              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
              by haitham sharabati
              Hello engineers šŸ˜€,
              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
              šŸ”§ Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
              šŸ’€ Problem:šŸ˜…
              - Device shows ā€œAdministrator Passwordā€...
              08-07-2025, 04:54 AM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • bestrafer
              Lenovo L460 LAN issue after BIOS dump flash
              by bestrafer
              Hello everyone.
              I have L460 Type 20FV (2 X 8MB bios chips) with no boot issue after BIOS update (black screen with restarts, common issue on this model + BIOS update).
              BIOS dump(s) from this post https://www.badcaps.net/forum/showpo...7&postcount=27 makes the laptop boot absolutely fine, no delays, etc..
              But there is an exclamation mark in the device manager for the LAN card right after fresh OS installation - LAN naturally doesn't work. I saw requests like "BIOS: fix LAN" on other sites.
              Could someone point on a direction...
              01-31-2023, 01:14 PM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • greelidd
              K6604J Vivobook RTX 4070 BIOS Dump Request
              by greelidd
              Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
              Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
              09-01-2025, 06:14 PM
