Flash bios
  • Esse
    • Apr 2014
    • 317
    • TOGO
    Flash bios
    Please can somebody tell step by step how to flash bios and what is a dump file
  • Mario
    • Sep 2007
    • 64
    Re: Flash bios
    I use a tl866cs universal programmer. They read quite a lot of chips. Ch341 is cheaper and can read most bios chips if you only want to program bios.
    I use sop to dip adapters desolder bios. Put it in the programmer and back it up onto the computer. I select tbe right chip and there is a dropdown menu to read the contents. It just reads the contents of the chip and thats a bios dump.
    I would then open the new bios file and click program to write to the chip. Solder it back to the main board and it should hopefully work.
    I can try taking photos of the process if you want. Let me know
    Dump file is the output contents of what was read from the bios chip
    Hope it helps. My English isn't to great. I hope readable....
    • Esse
      • Apr 2014
      • 317
      • TOGO
      Re: Flash bios
      It can very clear for me if you can illustrat with photo.thanks
      • rtstorm
        • Feb 2012
        • 971
        • Croatia
        Re: Flash bios
        Can someone explain differance betwwen BIOS and EC, and how to find EC on board?
        ...the quieter you become the more you are able to hear...
        • Esse
          • Apr 2014
          • 317
          • TOGO
          Re: Flash bios
          What is EC?
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            Re: Flash bios
            Embedded controler
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • haitham sharabati
              by haitham sharabati
              Hello engineers 😀,
              🔧 Device Info:
              - Model: HP 15-da2007ne
              - Product Number: 8XF55EA#ABV
              - Serial Number: CND0338P0D
              - CPU: Intel Celeron N4000
              💀 Problem:😅
              08-07-2025, 04:54 AM
            • cr4zychriss
              by cr4zychriss
              • Rebrand: PC Specialist
              11-14-2025, 04:04 PM
            • Citymin
              by Citymin
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • TyMercer
              Can I flash a working BIOS from one computer to another of the same make, model, etc?
              by TyMercer
              Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
              11-13-2025, 09:39 PM
