DV5-1040ee bios need.
  • nazrul145
    • Jan 2014
    • 333
    • BD
    Hello friend, I need this DV5 bios.
    With this laptop bios no display, But with hp server bios its caps lock blink
    3 times. That means RAM problem but i have Change RAM but caps lock blink 3 times.
    also change processor. It has nvidia graphics. Also reflow it.
    So i need confirm ok bios.
    Or advice pls.
    DAQT6AMB8F0 Rev. F
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: DV5-1040ee bios need.
    backup original bios
    two possible motherboards in this model, hence two bios
    Im Back... sort of...
    • nazrul145
      • Jan 2014
      • 333
      • BD
      Thanks ala_borbe, I have tried this bios. But caps lock blink 3 times.
      with orginal no blink caps lock also no display.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        have you trued both files?
        have you tried reflow? its nvidia
        here is schematics if needed
        • nazrul145
          • Jan 2014
          • 333
          • BD
          Try both file also reflow nvidia.
          but 3 blinks.
          • Pascal Komlassan
            • Jan 2017
            • 806
            • TOGO
            HP DV5 Intel/nvidia
            • rookieme
              • Oct 2014
              • 396
              • Greece
              does is have AMD cpu?
              If yes use only one RAM and swap it at both slots for a try.
              • watanirar
                • Dec 2018
                • 24
                • youssoufia
                Thanks PASCAL KOMLASSAN
                • toufik sat
                  • Feb 2016
                  • 134
                  • los angles
                  • toufik sat
                    • Feb 2016
                    • 134
                    • los angles
                    • kader1001
                      • Mar 2015
                      • 10
                      • algeria
                      thanks
                      • YMK
                        • Mar 2020
                        • 13
                        • Tajikistan
                        Originally posted by Pascal Komlassan
                        HP DV5 Intel/nvidia
                        dump worker thank you
                        • hizmetpc
                          • Oct 2016
                          • 4
                          • türkey
                          DV5-1225ET
                          DAQT6AMB8F0 REV F
                          SN CNF9142Y7G
                          İNTEL AC82PM45
                          NAVİDİA G96-G30-C1
                          KB3926QF CO
                          bios lütfen
                          • HAMIDBRAHIM
                            • Feb 2021
                            • Maroc
                            HP DV5 Intel/nvidia
                            MERCI
                              SMDFlea commented
                              Editing a comment
                              Post in english please !!!
                          • ArtMov
                            [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                            by ArtMov
                            Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                            1. I made overclocking lock disabled the default in amibcp
                            2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                            03-31-2023, 01:30 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • BrentH561
                            Elitedesk 800 G6 SFF Bios Password Lock XM25QH128A (3.3v) - Am I doing this right?
                            by BrentH561
                            Hello everyone, I am looking for help to make sure I am on the right track to remove lost BIOS Admin password on an HP EliteDesk G6 800 SFF. I recently purchased this on ebay and the seller is willing to accept a return but I have already installed my new HDs, NVME, and setup proxmox so I would like to keep it.
                            Here is the hardware identification specs:
                            HP EliteDesk 800 G6 SFF
                            Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                            Serial No: MXL1223499
                            Product No: 26S74UT#ABA
                            BIOS/IC chip seems to be the 4 pin XMC XM25QH128A (3.3v). However most
                            08-23-2024, 08:36 AM
                          • jbonavita
                            by jbonavita
                            Some issues
                            Things I tried
                            04-29-2025, 09:38 PM
                          • Wahaz
                            by Wahaz
                            10-30-2023, 08:42 PM
