HP 15-n018TU BIOS FILE
  • dilip.pawar31
    • Nov 2014
    • 59
    • india
    HP 15-n018TU DA0U81MB6C0
    WITHOUT GRAPHIC
  • ghojariya abdul
    • Jul 2014
    • 39
    • india
    Re: HP 15-n018TU BIOS FILE
    hello every one.
    i need daou83mb6co with grapihics motherboar bios.
    please help.!!!!!
    • nazrul145
      • Jan 2014
      • 337
      • BD
      hi ghojariya abdul..
      Give full model also upload your old dump
      • dspok
        • Jan 2014
        • 553
        • Nepal
        Originally posted by ghojariya abdul
        hello every one.
        please help.!!!!!
        backup and try attached.
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          here are all variants (4 different motherboards in this model)
          virgin bios, need to be fixed with NBDmiFit
          Im Back... sort of...
          • faisalali
            • Mar 2016
            • 25
            • pakistan
            need hp 15-n da0u81mb6c0 bios with graphic.
            • teqcom
              • Nov 2015
              • 311
              • malasyia
              • teqcom
                • Nov 2015
                • 311
                • malasyia
                • m0seba
                  • Mar 2016
                  • 38
                  • egypt
                  i need help 15-n240se DA0U82MB6D0 REV D
                  • jatoi
                    • Jan 2015
                    • 83
                    • pakistan
                    thanks dilip
                    • talat1
                      • Jun 2017
                      • 17
                      • gaza
                      thanks
                      • sureshbobby
                        • Mar 2015
                        • 137
                        • India
                        Hi friends What bios machine you are using, am unable to read this flash with MINIPRO tl866a
                        • atkari.p
                          • Aug 2017
                          • 9
                          • India
                          WITHOUT GRAPHIC
                          thanku sir
                          • toufik sat
                            • Feb 2016
                            • 136
                            • los angles
                            thanku sir
                            • mo4nis
                              • Dec 2018
                              • 55
                              • maroc
                              thinks
                              • Fadda88
                                • May 2017
                                • 12
                                • Italy
                                thanks
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  Hi everyone
                                  09-06-2025, 05:47 PM
                                • iZakre
                                  HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                  by iZakre
                                  Hello everybody!
                                  To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                  The thing is that I had installed TeamViewer and could log into the computer...
                                  02-19-2023, 02:27 PM
                                • Forest79
                                  by Forest79
                                  07-23-2023, 07:39 AM
                                • maanee11
                                  Help to get Lenovo BIOS bin file for Thinkpad T560
                                  by maanee11
                                  Hello Everyone,
                                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                  05-15-2022, 11:59 AM
