I have and Asus N550JK laptop with suspect bad bios. I have to reprogram the bios chip directly. Ther is just one chip. Can somebody provide a bios dump for this laptop. I can not find any on the internet i I dont know how to make one from the bios provided by Asus. Thx.
Asus N550JK bios dump needed
Re: Asus N550JK bios dump needed
Hi, thx for the help...here is the bios dump from the laptop. I do not now how to repair bios files...or maybe somebody has a link to a site where I could learno more about it? Anyway here is the bios dump from the Asus. Also take a look at my other post where I have a bricked toshiba L50 with a faulty bios...ThxAttached FilesComment
pls try thisAttached FilesIm Back... sort of...
hello,Hi, thx for the help...here is the bios dump from the laptop. I do not now how to repair bios files...or maybe somebody has a link to a site where I could learno more about it? Anyway here is the bios dump from the Asus. Also take a look at my other post where I have a bricked toshiba L50 with a faulty bios...Thx
have you solved your probleme ?
I have the same problem and I can not find a solution. The preprogrammed bios chip I bought does not work and I do not have the tools to fix my bios. By the way I do not know how to do it and if someone can tell me about the tools and how to use them to repair the bios, I'm interested.:sourire:Comment
by ArkzGHey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
What I currently have available:
- Model: FA506NF (2021)
- BIOS chip: GD25LQ16 (16Mbit/2MB)
- Tools: CH341A programmer ready to use
Does anyone have either a clean 2MB .bin dump of this model,...-
Channel: BIOS Requests ONLY!
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by kodoxneed original bios dump, original bios has flashed by other technician before me.
attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
unit info:
Model: Asus ExpertBook B1400CBA-0711A1235U
S/N: R6NXNZ006657238
CN: 7F6F
Mainboard Code: B1500CBA R2.1...-
by piratiHello everyone,
by DynaxSCHi,
Usually on ASUS boards it worked...-
- Loading...
