Need Bios for Toshiba C855 - procesor upgrade turns off in 30 minutes
  • angel-boy
    • 550
    • Romania
    Need Bios for Toshiba C855-1DK
    I changed the processor from intel B820 to i3 2370M and laptop turns off in 30 minutes
    i understand that the bios is set to do this.
    mainbord is PLF / PLR / CSF / CSR UMA MB REV2.1
  • nazrul145
    • Jan 2014
    • 333
    • BD
    Re: Need Bios for Toshiba C855 - procesor upgrade turns off in 30 minutes
    Its not bios problem, I think your motherboard not supported this processor.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      https://www.badcaps.net/forum/attach...0&d=1425472084
      Im Back... sort of...
      • angel-boy
        • 550
        • Romania
        what is the file F680.FD , is not a compatible bios file
        if not bios problem , what processor will my board support ?
        • shada
          • Feb 2015
          • 5
          • india
          its not a bios problem
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            @angel-boy
            rename to bios.rom or bios.bin
            • angel-boy
              • 550
              • Romania
              thanks, i will try tomorrow, hope will work !
              • angel-boy
                • 550
                • Romania
                not working , turns off in 30 minutes
                • angel-boy
                  • 550
                  • Romania
                  any help please ?.....................
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1489
                    • portugal
                    Hi there ,
                    the problem is that the chipset you got on the motherboard does not support the cpu you have , it will ALWAYS shutdown around 30 minutes , you have no chance here , for bether details , chek the PCH chipset you have , and chek on intelwebpage for compatibility
                    i add this problem , after replacing a board , didnt noticed the PCH was another revision and the I5 cpu from the client didn't worked on that board , shuthing it down after 30 minutes , so ordered the best cpu available for the PCH i add on the board and working until now !
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1489
                      • portugal
                      you can trust on this info , simple chek the PCH , HM55 HM65 HM88 whatever is the revision , and confirm with intel webpage and you will see the cpu you're trying to add will not be supported
                      • angel-boy
                        • 550
                        • Romania
                        ok Thanks , topic can close.
                        • camel_git
                          • Apr 2014
                          • Spain
                          Hello. I am needing a bios dump for the kbc bios (power on) for this model. I have tried to extract it from the original toshiba file with no success. The mobo it is not powering on, and as far as I can go i guess the kbc bios it is corrupted. Can anyone help me??
                          Regards
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            post no 2 bios attached
                            • vedoza
                              • May 2015
                              • 37
                              • newyork
                              Hi dear friends,
                              toshiba Satalite c855
                              Power on
                              its not working display,does not display
                              pleas help
                                • 30948
                                is the laptop dead, or do you get a picture with an external monitor connected?
                                • vedoza
                                  • May 2015
                                  • 37
                                  • newyork
                                  yes because not display
                                  • soslaptop
                                    • Mar 2014
                                    • 3
                                    • algeria
                                    Its not bios problem but pdh sjtnv not supported this cpu
                                    • maha2005
                                      • Oct 2013
                                      • 20
                                      • tunisia
                                      thanks it's working
                                      • beydere
                                        • Nov 2020
                                        • 5
                                        • turkey
                                        Make clean me region bios
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • YvD-Electronics
                                          Request BIOS files to flash Toshiba C55-A-1TX laptop
                                          by YvD-Electronics
                                          I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
                                          Why I am pretty sure I need this to repair?
                                          1) Power supplies seem OK.
                                          2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
                                          3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
                                          4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
                                          08-09-2024, 10:05 PM
