hp 2000-2b19wm bios
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    hp 2000-2b19wm bios
    hi
    this laptop has dead bios, i downloaded the bios from the vendor but i found 2 files. which one i must program??
    or if some one has the bios dump ?
    thanks in advance.
    http://ftp.hp.com/pub/softpaq/sp67001-67500/sp67259.exe
    the files are: 0188b.fd and 02128.fd
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp 2000-2b19wm
    first you need to backup your old bios, than i can help you prepare new bios for flash
    Im Back... sort of...
    • mazloum
      • Sep 2012
      • 503
      • Lebanon
      Re: hp 2000-2b19wm
      here the file but it is almost empty:
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        Re: hp 2000-2b19wm
        pls try to properly backup your bios
        not read good, important data missing, dmi missing, not a good dump
        from what i have seen from partial dump you provided it should be 0188b model
        here is bios file, but dmi data is missing, need full dump of your bios so it can be fixed
        if you flash this file, laptop will prompt error every time you power it on, but at least you can test
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          Re: hp 2000-2b19wm
          Use the hp tools to fix the missing data
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            Re: hp 2000-2b19wm
            that hp tool always give me a hard time so i use hex editor to fix dmi, just copy>paste from old to new file faster and easier for me
            • cyberhack
              • Feb 2013
              • 466
              • Uk
              Re: hp 2000-2b19wm
              Yes you are right but some times the old file missing, bad read.
              • mazloum
                • Sep 2012
                • 503
                • Lebanon
                Re: hp 2000-2b19wm
                thank you very very much
                works like a sharm
                • mazloum
                  • Sep 2012
                  • 503
                  • Lebanon
                  Re: hp 2000-2b19wm
                  thank you cyberhack , i used the nbdmi tool and every thing works great
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    Re: hp 2000-2b19wm
                    nice to hear it works
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
