HP 15-bs026nc BIOS request
  • Kralik
    • Dec 2023
    • 6
    • Czech Republic
    Hi, I need a BIOS for:
    HP Laptop
    Model: 15-bs026nc
    ProdID: 1TU43EA#BCM
    SN: CND7393JSD
    Bin dump from existing BIOS (user probably flashed wrong BIOS?):
    Thank you very much for any help!
  • m1ch43lzm
    • Mar 2019
    • 1123
    • Peru
    Most likely failed/interrupted BIOS update
    Try, BIOS extracted from HP website, serial/win key inserted
    HP Notebook - 15-bs026nc
    BID 08328
    BIOS ver. F.75
    S/N CND7393JSD
    DMI + Win key 210000-21103F
    • Kralik
      • Dec 2023
      • 6
      • Czech Republic
      Thank you for your effort, but unfortunately, I still have no video output and my caps lock is blinking in pattern: [- - - . .]
      • m1ch43lzm
        • Mar 2019
        • 1123
        • Peru
        HP really messed this up, not extracting properly the BIOS for your laptop from the .exe
        They used the same BID for Skylake/Kaby Lake (6th and 7th gen) and Kaby Lake Refresh (8th gen)
        There's 2 BIOS variants 08328"A" and 08328"B", latest version that should work for 6th/7th gen is F.52, yet the update.exe only extracts one, overwriting the other....
        They use the same PCB LA-E791P, just the motherboard model and BID is not enough to differentiate BIOS variants; had to do some tricks to get the .exe to extract properly...
        Do not update BIOS to F.75, it will likely brick it again
        Try, 08328"B" variant, CPUID 406E3 and 806E9 (6th and 7th gen)
        S/N CND7393JSD
        08328B F52 Kralik.rar
        Also attached 08328"A" variant, CPUID 806EA just in case, no DMI
        • istvanszasz99
          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
          by istvanszasz99
          Product Name: Razer Blade 15 (2022)
          Product ID: RZ09-0421
          Motherboard: CH580
          BIOS Versions I work with: 2.02 & 2.06
          Bios File Size: 32,768 KB
          Dear Forum Readers!
          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
          !!! MY RAZER BLADE...
          11-24-2025, 05:52 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
        • Loli Popu
          DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 03:28 AM
        • drux
          Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
          by drux
          I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
          Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
          These models have AMI/Aptio BIOS.
          Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
          11-03-2024, 01:18 AM
