BIOS file needed HP PROBOOK 445 G5 DA0X9KMB8E0 REV E
  • mohammed mohan
    • Nov 2017
    • 199
    • z
    BIOS file needed
    HP PROBOOK 445 G5
    DA0X9KMB8E0 REV E
    S/N 5CD92213CN
    No backup available
    Mohammed Mohan
  • m1ch43lzm
    by m1ch43lzm
    Hi everyone
    09-06-2025, 05:47 PM
  • to5it0
    by to5it0
    10-24-2025, 01:35 AM
  • Forest79
    by Forest79
    07-23-2023, 07:39 AM
  • studdy05
    Bricked HP Probook 450 G7 Bios questions
    by studdy05
    Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
    Ive got...
    07-08-2025, 09:24 PM
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
