Bios File ✅ LG GRAM 14Z90P-G.AJ63B4 Aporte a la comunidad de tecnicos. I hope these bios file can help the community. sorry my English
			by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
 I have opened the laptop and identified the main BIOS chip...2 Photos-
							Channel: BIOS Requests ONLY!
			by CityminHi all,
 S/N : 5RNK9FFT70...-
			by m1ch43lzmHi everyone
 There's also an extra OTP Secu.R...-
			by Forest79Hello,
 However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
			by maanee11Hello Everyone,
 I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
 https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
 In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
- Loading...
