hp ZBOOK 14U g6 bios request
  • voltex
    • Sep 2018
    • 5
    • morocco
    hi my friend i have dead hp ZBOOK 14U g6 with corrupted bios can you fix my dump please
  • hoaca388
    Badcaps
    • Jan 2022
    • 12248
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • Mohammed Almasri
      Bios Password Removal Request for HP ZBOOK G5, Tried the methods in the main guide and did not work
      by Mohammed Almasri
      SN: 5CD9423FGG
      16 and 32 MB files are taken with T48 after desoldering both chips
      thanks in advance...
      09-09-2025, 10:29 AM
    • jbonavita
      by jbonavita
      Some issues
      Things I tried
      04-29-2025, 09:38 PM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • Wahaz
      by Wahaz
      10-30-2023, 08:42 PM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
