Hello friends, can you help me, I need the bios / dump of a ACER TravelMate P215-54 Thank you very much
TravelMate P215-54 Need Bios
Tags: None
post S/N Service Tag or SNID, full name and model, motherboard model
read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by x14nl34lHi, I need a bios dump for my Acer TMP614 (tmp614-51-g2-5442 bios dump). Thanks.
- Loading...
