HP Elitebook 820 G4 BIOS repair assistance required
  • Wutru
    • May 2024
    • 8
    • Netherlands
    Hi guys,
    If someone would be able to provide some expertise, I'd be very grateful.
    BIOS Corruption - Cause
    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC. So the BIOS was not corrupt but at least no video out.
    EliteDesk Repair
    I had this exact same situation happen to me (because then I did *not* include the MSFT keys) on a HP EliteDesk 800 G2 DM, which I managed to repair by desoldering the SPI ROM and replacing the BIOS region with UEFITool 0.28 with a fresh BIOS region extracted from an HP update executable- That is all I had to do.
    Their behaviour was fully shared between the Elitebook and Elitedesk, no video, but able to get in BIOS and trigger beeping with Esc or F10.
    My tools:
    - CH341A (3.3V modification)
    - EZP2023+
    - UEFITool A78 (latest I think)
    - UEFITool 0.28
    Elitebook Repair
    Because of this earlier success, I went straight ahead with this machine. Desoldered the ROM, dumped it and replaced the BIOS region, and resolder it.
    Then it had the following behaviour:
    1. When connecting power (battery or ext. power), the charging LED flashed white/amber (white/orange) for a few seconds.
      1. This would indicate, according to the 820 G4 Maintenance and Service Guide (page 70): "The embedded controller is recovering the boot block or DXE. Since it takes 10 sec. or so to load the DXE image and get video in the DXE case, this blink code is necessary. (SureStart)"
    2. Then it went off for a few seconds, and then the charging LED came back on solid amber/orange, either with or without battery present.
    3. But the machine would not start up, no power LED, no fan spin nothing.
    4. Removing the power, holding the power button, windows + B, or other button combinations etc. all did not work.
    5. When reconnecting the power, I experienced the same as step #2 & step #3.
    I then went ahead and removed the board from the case and disconnected the CMOS battery from a few minutes. The behaviour changed:
    1. A lot more LEDs(I think WiFi, charging and power) came on, and stayed on.
    2. The Power LED came on when pressed, and after a few seconds the fan started spinning up to max speed
    3. Still no video.
    I have backup of the original dump, (triple verified before reprogramming anything) and the repaired BIOS. There is a separate 64MBit EC ROM and the Embedded controller is a Nuvoton NPCE586HA0MX.
    Any help will be greatly appreciated.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12363
    Originally posted by Wutru
    Hi guys,
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • Wutru
      • May 2024
      • 8
      • Netherlands
      Hi hoaca388, thank you for your reply, please see my answers in italic below:
      Originally posted by hoaca388
      (list of points)
      You MUST:
        • I have read this (very well written) guide and used it up to get to this point where I get stuck
        • I have tried the methods in this (very well written) guide and used it up to get to this point
        • I have succeeded with the methods in that (very well written) guide on another machine, the EliteDesk 800 G2 DM
        • But the EliteBook 820 G4 does not succeed as it behaves differently
        • I have used the search function extensively, but it is difficult to find threads only related to elitebook G4 models. It appears the search function ignores the G4 part
        • I have seen similar threads but they usually include CAPS Lock LED blinking or other symptons and totally different hardware models
        • I did not find sufficiently related threads to an HP Elitebook G4 (820/840/850) discussing problems (all I could find were just bios dump or repair requests) so I decided to open a thread
        • Product Number: Z2V91ET#ABH
        • Serial: 5CG8210XWC
        • GbE: 10:62:E5:4F:8A:96
        • I think I did this
        • See attached zip file with my dumps in this post
        • I have included:
          • Original dump
          • clean HP BIOS extract
          • my repaired BIOS by replacing BIOS region with UEFITool 0.28
        • I am hesitant to desolder the EC because it is surrounded by 0402 SMD resistors
        • When connecting power (battery or ext. power), the charging LED flashes white/amber (white/orange) for a few seconds.
        • Then it goes off for a few seconds, and now the Power, charging and WLAN LED turn on, the power button LED turns on, and after a few seconds the fan starts spinning to max speed
        • No video, black screen
      • hoaca388
        Badcaps
        • Jan 2022
        • 12363
        HP EliteBook 820 G4 Notebook PC
        • Wutru
          • May 2024
          • 8
          • Netherlands
          Thank you. Sadly, no improvements are noticed.
          I have included a dump of the EC.
          • hoaca388
            Badcaps
            • Jan 2022
            • 12363
            New EC
            • Wutru
              • May 2024
              • 8
              • Netherlands
              Thank you. No improvements however - charging LED keeps blinking, with an extremely short blip of the power LED.
              Managed to fan spin once, but it went to max speed. No video or even impression of backlight turning on.
              Now it just it won't fanspin even and keeps at white/orange blinking
              I don't know how to proceed. I would not suspect hardware issues because the computer worked fine initially until I rebooted it after setting custom Secure Boot keys in Linux
              • Wutru
                • May 2024
                • 8
                • Netherlands
                I have ordered and received new Winbond chips for both the BIOS and EC, and reflashed them with the files in this thread.
                No improvement yet so it is not that I broke the chips with temperature.
                Can someone please double check the files? Maybe the BIOS got partially repaired by the EC (SureStart) but become damaged, then the EC got corrupted by the damaged BIOS?
                • Wutru
                  • May 2024
                  • 8
                  • Netherlands
                  Sadly I had another mishap with another G4 820.
                  I have included dumps of BIOS and EC ROMs
                  I would be very grateful if this machine could be restored.
                  Code:
                  Model: HP EliteBook 820 G4
                  Serial: 5CG820571S
                  MAC: 10:62:E5:4D:DC:E3
                    SMDFlea commented
                    Editing a comment
                    Thread merged.
                • Wutru
                  • May 2024
                  • 8
                  • Netherlands
                  New EC
                  Hi sir, can you please help me out? I'd be very grateful!
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12363
                    Code:
                    Serial: 5CG820571S
                    • STKR123
                      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                      by STKR123
                      Greetings badcaps community,
                      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                      I learned that desoldering...
                      10-29-2024, 06:03 AM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • Guest
                      Elitebook 850 G5 BIOS bricked
                      by Guest
                      I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                      I assume the BIOS update failed, so I searched for the BIOS chip.
                      I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                      However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                      Can the corrupted...
                      03-24-2025, 01:21 AM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
                    • lap-top123
                      Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                      by lap-top123
                      HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                      Hp Elitebook 850 G8
                      ProdID 52W98EC#ABD
                      SN# 5CG1458XQ7
                      Mac-address #1: 84:14:4D:2C:4B:5B
                      UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                      Mainboard : 6050A3216701-MB-A01(A1)
                      08-20-2025, 07:28 AM
