hi guys , who can share bios dump HP630
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    board model
    chicago_cp_hpc
    MV_MB_V2
    KBC its a ITE8518e
    bios KBC MXIC25L4006E its 512kb
    thk in advance
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: hi guys , who can share bios dump HP630
    im trying with this one https://www.badcaps.net/forum/showthread.php?t=34284 asked by Dycc , gonna try it now , but board revision is a bit different let see
    meanwhile if someone have this board revision model and can share the bios i apreciate
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      Btw im only with the board here , tryed with the original dump no image on external and also with the dump ive found here . should this laptop send image on external !??!( i know that some models of laptop dont send to external on the beggining only in windows for ex . can anyone let me know this info , and of course a precious dump for the exact board model would be perfect!
      • dj_ricoh
        • 2073
        • uk
        hp always send signal in external after 5 sec.
        it has a point if he does not detect the internal display goes on external.
        don`t be fool with that one because some ppl test only in external and it wont work with internal buuuuuuuuuuuuuuuuut everybody knows its a bad video chip.
        Cheers!
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          good , so then they screw up this shit out and sent me to fix it ... niceeeee ... more good work once again !!!!! must get this correct dump KBC and MAIN for that revision board if someone have it please send .
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            fast post 2% before laptop dies.
            Ok so this laptop gives image on external , i forge to mention its a UMA board , so it gives image , and with HDD on doesn't past post , without hdd it pass post but mention not having operative system ,
            meanwhile in both ways after 50 second more or less , machine shutdown!!!
            what the hell is going on with this machine
            • highpulse
              i hate HP
              • May 2013
              • 1488
              • portugal
              back , my mbp is now charging , well this problem is weird , its not getting hot at all tough fan start slow and 15 sec after fan is fast, then is like this for 30 sec then shutoff , originally this machine was in other store (i know them ) they told me that they read the main bios (but didn't change anything on it or erase or ref lashed .and since they didn't found the KBC bios to flash they reflowed the ITEXPEAK and problem persisted it only don't remember if the machine was doing this issue(shutting down after a while )its quite weird issue. well but its 1:20 am already , and working since 8 :30 am , tired of computers for today, later on is a new day and i hope to find out what the hell is going on with this tomorrow .
              meanwhile thx to all
              • highpulse
                i hate HP
                • May 2013
                • 1488
                • portugal
                well was still with this dam machine on my mind and went across internet to find out some solutions and arrived to a conclusion for this shutdown thing.. they must be blow away the BD chipset , since its quiet common on several machine with core i3 i5 i7 usually with this chipset , major part who make the chip replace solve they're problems and no more shutdown or any thermal errors. well its a good lessons for does who think reflowing things randomly can fix things , but its NOT .. or you can what you're doing or don't touch !!!
                well sleep well guys , see you later
                • dycc
                  Vision
                  • Nov 2011
                  • 624
                  • Côte d'Ivoire
                  View BID xxxx at the end of the dump you made a backup, and flash the appropriate.
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1488
                    • portugal
                    thk you dycc , but board as outher problems as well , but will keep them in hand for sure thk
                    • dj_ricoh
                      • 2073
                      • uk
                      I saw a Toshiba that did not supported its original i7 cpu don't know what happen keep powering off or bsod . changed with a i5 and everything was ok I install that i7 in another one and it run perfect.
                      this is not a info that may be relevant to you but maybe a good thing for the future.
                      • highpulse
                        i hate HP
                        • May 2013
                        • 1488
                        • portugal
                        no , hp630 was with hm55 damaged , replace must arrive very soon , BD are a wast of time .
                        • حمدالله
                          • Oct 2018
                          • 5
                          • مصر
                          La-c921p bios+ec
                          • Zibbo
                            • Mar 2017
                            • 201
                            • Zimbabwe
                            Thank you dycc, I just managed to fix a motherboard that has been giving me a headache for three days! The second file had the same BID
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • DynaxSC
                              by DynaxSC
                              11-17-2023, 10:56 AM
                            • grimacelord
                              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                              by grimacelord
                              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                              Motherboard model number: DA0PAMB46A1 REV: A
                              Secondary motherboard model number: 0PAB
                              SKU: 685K4UA
                              Serial number is: 5CD3223BJP
                              Recently reflashed this laptop with latest BIOS and once...
                              05-07-2024, 08:06 AM
                            • DynaxSC
                              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                              by DynaxSC
                              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                              11-06-2022, 05:22 PM
                            • TacticalFahrrad
                              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                              by TacticalFahrrad
                              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                              06-30-2025, 04:09 AM
