S5506MA-WS76 Corrupted BIOS
  • marc_ytos
    • Apr 2020
    • 146
    • cdmx
    Corrupted BIOS
    Greetings, can you help me with my BIOS? It seems to be corrupted. It doesn't display anything on the screen. My motherboard is 6050a3553002 S5406MA-MP-GBM. Serial number: SAN0KD011407427. Thank you very much in advance.​
  • danito
    • Jun 2016
    • 986
    Originally posted by marc_ytos
    Corrupted BIOS
    try
    • marc_ytos
      • Apr 2020
      • 146
      • cdmx
      Originally posted by danito
      try
      Greetings, thanks for the attempt, but with this one it only turns on for a few seconds and then turns off. It didn't work.
      • ferah831208
        • Aug 2019
        • 64
        • Cuba
        I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that I can find the module I believe could be bios REGION, but I would have to use the first 30 percent of bios image from original bios dumped(where flash descriptor for example should be) because I cannot find the way to separate this image in modules. And my concern is original bios image might have data corruption in different modules. Does anyone have any info about this or recommend some method or utility I can use? thanks in advance and sorry maybe for my ignorance πŸ˜”
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • peste
        • 12945
        • ROMANIA
        post S/N, full name and model, motherboard model, etc.
        post the contents of the bios chip even if it is corrupted..
        • macabook
          πŸ› οΈ MSI GP75 Leopard MS-17E71 – No Display, Deep BIOS/EC Troubleshooting
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • TylerHyde21
          Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
          by TylerHyde21
          Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
          I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
          I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
          This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
          06-29-2024, 10:38 AM
        • Loli Popu
          DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
          by Loli Popu
          Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
          12-13-2024, 08:29 AM
          by Vesko356
          08-11-2023, 03:27 AM
        • oragano
          ASUS ex-b250-V7 motherboard bios corrupted - by me
          by oragano
          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
          10-17-2024, 02:53 AM
