Bios file for Zenbook UX3402ZA/Q409Z
  • Mustafaali
    • Aug 2025
    Looking to reprogram the bios chip. Can someone provide the bios dump for flashing. Possiblely corrupted bios (startup very slow, sound and mic not working)
    Asus Zenbook
    UX3402ZA
    Motherboard:N85936FA
    HQ3120JW60000
    22185RS
    N104NBLP0009M1MB 200
    Bios Chip: XM25QH80BHIG
    Current Bios version: 310
    s/n: N2N0LP00C91706A
    ​please help me get a file that i can use to program the bios chip. Thank you!
    • 22289
    Post your bios backup even if it`s corrupt.
    • Mustafaali
      • Aug 2025
      Thank you for the quick response. Attached my original bios bin file
      • m1ch43lzm
        • Mar 2019
        • 1126
        • Peru
        Wrong chip, this is Thunderbolt firmware
        Look for XM25RH256C or similar chip with "256" in the name
        It's on the back of the board
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
