Asus ExpertBook B1400CB Bios Dump Needed
  • kodox
    • Jul 2017
    • 328
    • Indonesia
    need original bios dump, original bios has flashed by other technician before me.
    attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
    unit info:
    Model: Asus ExpertBook B1400CBA-0711A1235U
    S/N: R6NXNZ006657238
    CN: 7F6F
    Mainboard Code: B1500CBA R2.1
    • 21173
    Scan the QR codes and post what they say or post pictures of them
    • kodox
      • Jul 2017
      • 328
      • Indonesia
      here are the QR codes
      • kodox
        • Jul 2017
        • 328
        • Indonesia
        anyone....?
        • shiyab
          • Sep 2023
          • 1506
          • india
          Originally posted by kodox
          anyone....?
          hi try
          • kodox
            • Jul 2017
            • 328
            • Indonesia
            Originally posted by shiyab
            hi try
            thank's but still remain the same as before
            • kodox
              • Jul 2017
              • 328
              • Indonesia
              anyone else....?
              i've changed suspicious parts still no change, i'm sure the problem is in the bios and attached backup is incorrect for this model that flashed to the chip by other technician
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • TacticalFahrrad
                [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                by TacticalFahrrad
                I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                06-30-2025, 04:09 AM
              • angel148644
                Bios Asus ExpertBook B2402CBA
                by angel148644
                Good day friends, This laptop turn on and show a message "Please follow the steps below to recover your bios", try it to repair with Asus EZ Flash Utility & Usb, but didnt work. Remove bios and copy, then download bios version 308 from Asus web and use "AMI PFAT" to obtain Region Bios.
                Now the problem its, I cant open the original bios with CSME v16.0.15.1662, to replace region and Me region. Someone can help me whit this please. Thank you for your time.
                Me Region Version: 16.0.15.1735
                Logic board its B2402FBA MB REV: 2.0
                Laptop model...
                12-17-2024, 02:42 PM
