Alienware 17 R4 (6th gen) bios problem
  • yasin4286
    • Mar 2021
    • 26
    • my workshop
    Hello friends. I have been struggling with this device for several months. The problem is that the laptop is 6th generation and every BIOS I find is 7th generation. In the BIOS settings, it says Kaby Lake in the integrated graphics. The graphics drivers are not installed properly in Windows either. I would be grateful if any of my friends could help me finish this laptop.
    Model : Alienware 17 R4 (6th gen)
    Motherboard : LA-D753P rev 1.0(A00)
    CPU: 6820HK​
    • 22279
    CPU: 6820HK
    Please read https://www.badcaps.net/forum/troubl...before-posting ,and post the service tag.
    Make a backup and post it or try this bios - https://www.badcaps.net/forum/troubl...43#post3519543
    • yasin4286
      • Mar 2021
      • 26
      • my workshop
      service tag : 3J47RF2
      • yasin4286
        • Mar 2021
        • 26
        • my workshop
        any help
          • 22279
          any help
          • yasin4286
            • Mar 2021
            • 26
            • my workshop
            That's exactly the problem. The previous repair shop didn't back up the BIOS. We have no backup.
              • 22279
              Ok, well .. try the bios i linked to.. https://www.badcaps.net/forum/troubl...43#post3519543
              • yasin4286
                • Mar 2021
                • 26
                • my workshop
                I tested this file before, unfortunately it didn't work. This laptop is literally a real challenge and a real predicament. Thank you for helping me.
                • yasin4286
                  • Mar 2021
                  • 26
                  • my workshop
                  My friends, is there anyone who can help me? May God bless you with good fortune.
                  • yasin4286
                    • Mar 2021
                    • 26
                    • my workshop
                    Hello again. I also changed the device’s vbios file and replaced it with vbios skylake. I even changed the CPU microcodes, which were previously both skylake and kaby, and set them to skylake.
                    Finally, surprisingly, in the BIOS, in the Intel graphics section, it still shows kaby lake and the graphics are not installed correctly, and after installing and restarting the system, Windows starts up but the image is black
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
                    • lucaszmn
                      by lucaszmn
                      Problem:
                      Initial Findings:
                      • I concluded that the
                      08-12-2025, 03:01 PM
                    • drux
                      Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                      by drux
                      I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                      Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                      These models have AMI/Aptio BIOS.
                      Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                      11-03-2024, 01:18 AM
                    • AquaMan Ua
                      by AquaMan Ua
                      05-17-2025, 09:40 AM
                    • traxformania
                      TONGFANG "GM7TG7P" Bios Password Problem?
                      by traxformania
                      I tried :
                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                      11-15-2023, 07:32 AM
