HP OMEN MAX 16-ah0006nf bios
  • madjid911
    • 412
    • France
    Can you clean this bios with a new image or clean the intel region please ?
    Because the laptop starts but no display, the shift key flashes 5 times long 3 times short, this indicates a corrupted bios according to my research, I did not find a bios like this model, so I attach the original one.
    For HP OMEN MAX 16-ah0006nf intel i7
    SN : 5CG5171Q12
    Motherboard : DOJO51-MV-GBM 6050A3604401-MB-A01 2025-03-18
  • volinakis
    • Jan 2021
    • 2877
    • N/A
    SN : 5CG5171Q12
    try
    • madjid911
      • 412
      • France
      Originally posted by volinakis
      try
      Hi, the result is the same, can you have a new image please?
      • volinakis
        • Jan 2021
        • 2877
        • N/A
        is extracted from bios update with your DMI in it. So, check for hardware problem.
        • madjid911
          • 412
          • France
          the sio chip must be dead then
            • 22286
            key flashes 5 times long 3 times short ,sometimes caused by loose ram slot pins or cracked solder balls under the SOC
            • JoWed
              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
              by JoWed
              Hello Community,
              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
              07-01-2025, 09:32 AM
            • mkdj
              by mkdj
              Dear all,
              10-19-2025, 04:41 AM
            • Dani Rahal
              hp omen 17-cb0247ng bios
              by Dani Rahal
              Hi can some one help me plz
              i have hp omen 17-cb0247ng (la h492p) it have bios problems and i flashed bios from usb the new one v53 and its boosting to bios but did not start to windows (blue screen of death) i tryed evry thig and not working
              i flashed bios with programer ( CH341A )and it will not boost to bios just fan working no disply now i flash the orginal bios back its working but no booting to windows same problem
              the bios from hp after extract have 4 bios file same size i tryed 4 of them not working
              i have the orginal bios if some one can see what the problem or...
              05-30-2025, 09:11 AM
            • Blur3195
              HP Omen 16-u0000sl. bios
              by Blur3195
              Hi, I have a problem with my HP Omen 16-u0000sl.
              I have a corrupted dump from which I extracted the DMI and inserted it into a stock BIOS. With the corrupted dump, the Caps Lock light blinks twice normally and twice quickly (BIOS corrupted). With the stock BIOS plus the DMI, the laptop starts a series of reboots but never initializes. I would be very grateful if someone could help me; I think maybe the DMI area is corrupted....
              08-22-2025, 11:24 AM
            • zerbatin
              HP Omen 16-c0825no BIOS.
              by zerbatin
              I have problem with my laptop. When I turn it on it do not POST. Black screen with FAN not working, When pressing CTRL+V/B I can go into BIOS update, but after auto restart there is no update screen. Nothing happen.
              I have tried using this DUMP but with no go,
              https://www.badcaps.net/forum/troubl...os#post3210916
              My winbond BIOS chip got fried as well after 4th attempt, now it is unsoldered and I am waiting for...
              07-17-2025, 02:14 PM
