Linx 1020 windows tablet bios required
  • Xohaib
    • Jul 2025
    • Pakistan
    I’m looking for a full 8MB BIOS dump (.bin) for the Linx 1020 tablet with the Intel Atom x5-Z8350 processor. My device is currently not powering on, and I believe the BIOS might be corrupted. I plan to reflash it using a CH341A programmer and SOIC8 clip.
    If anyone has a working Linx 1020 and could share a verified full dump from the SPI BIOS chip (usually Winbond 25Q64 or similar), I’d really appreciate it. A clean dump from a known working unit would help restore my board safely.
    If the dump is from a Z8300 variant, please note it — though Z8350 is preferred.
    Thanks in advance for your time and support!
    Best regards,
    • 21896
    Maybe you just need to clean the TXE firmware. Do you have a backup.
    • Xohaib
      • Jul 2025
      • Pakistan
      No sir i dont have a backup.
      • Xohaib
        • Jul 2025
        • Pakistan
        Hello got dump file from bios chip using ch341.Please can you guys check and fix it.clean me.
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • mkdj
          by mkdj
          Dear all,
          10-19-2025, 04:41 AM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • haitham sharabati
          by haitham sharabati
          Hello engineers 😀,
          🔧 Device Info:
          - Model: HP 15-da2007ne
          - Product Number: 8XF55EA#ABV
          - Serial Number: CND0338P0D
          - CPU: Intel Celeron N4000
          💀 Problem:😅
          08-07-2025, 04:54 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
