Lenovo Thinkpad X13 Gen 3 AMD locked bios
  • fulaphex
    • Jul 2025
    • 11
    hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
    Click image for larger version  Name:	20250709_180908.jpg Views:	0 Size:	7.69 MB ID:	3678851
    I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00".
    Click image for larger version  Name:	20250710_010407.jpg Views:	0 Size:	3.06 MB ID:	3678852 Click image for larger version  Name:	20250709_192756.jpg Views:	0 Size:	5.60 MB ID:	3678850
    While I'm waiting for the programmer to arrive I disassembled the computer and tried finding the BIOS chip on the motherboard - but I'm not entirely sure how to do that. My best guess would be that it is the 8 legged chip near the CPU - on the picture below it close to the left mount of the CPU cooler, a little to the right of it.
    Click image for larger version  Name:	20250710_013930.jpg Views:	0 Size:	8.70 MB ID:	3678854
  • fulaphex
    • Jul 2025
    • 11
    I managed to take a better picture of the chip I suspect to be the BIOS chip:
    I tried looking for that chip online and found this: https://www.digikey.co.uk/en/product...hJBch8Leh_0in8
    According to that spec sheet - it looks like it should be safe to read this with the 3.3V ch341a programmer? I am still waiting for the programmer to arrive - as soon as it does I'll try dumping the contents of that BIOS chip.
    Please do let me know if it looks like I'm about to burn this thing out somehow - it's going to be the first time I'm trying the whole chip programming business.
    • m1ch43lzm
      • Mar 2019
      • 1015
      • Peru
      W25Q128JW is 1.8V chip, you need an additional 1.8V adapter if using the CH341A, or you can damage the BIOS chip or the motherboard/CPU, as all Ryzen PC/laptops use 1.8V BIOS chips
      The one you linked is W25Q128JV, a different 3.3V chip
      But I think the password is stored on the EC (not on the BIOS chip) like on other ThinkPads
      • fulaphex
        • Jul 2025
        • 11
        I see - thank you for your answer! I guess the BIOS and EC chips could be on the other side of the motherboard? Or do you see something that resembles a BIOS/EC chip on the pictures I linked?
        In the meantime I disassembled the laptop further, took out the motherboard entirely, and found one more chip that could be BIOS/EC on the other side of the motherboard. It is W25Q128JW as well - but I will have the 1.8V converter for the ch341a programmer so I should be able to read both of them. I guess the next step is to read both those chips with the 1.8V reader and post the results?
        • m1ch43lzm
          • Mar 2019
          • 1015
          • Peru
          Check here for the schematics and boardview, NM-E422, it's the same as T14s Gen3 AMD
          https://www.badcaps.net/forum/troubl...gen-3a-nm-e422
          The EC (NPCX997) and the system BIOS are on the other side of the board
          You need a special programmer SVOD4 for this, that programmer is expensive, check this thread:
          https://www.badcaps.net/forum/troubl...-svod4-npcx997
          No way to erase password with just the CH341A, best to find a repair shop that will do that service
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • thxd43
            Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
            by thxd43
            Hello, first of all, excuse me, I am using the translator, English is not my native language.
            I have a Lenovo ideapad 330S - 14IKB laptop.
            The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
            02-23-2023, 08:37 PM
            by SMDFlea
            Bad...
            09-02-2021, 04:40 PM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
          • EleganceArog
            Lenovo ThinkPad X13 Yoga Gen 3. BIOS LOCKED. Need Bios to be cleared.
            by EleganceArog
            I have a
            S/N: [PW-042W7M]
            Type Number: [21AXS1B200]
            Motherboard: [LLX-2 MB 213016-SB]
            Bios is locked with a Password. I'm looking for a cleared bios bin to flash the laptop.
            I attached my backup bios.
            Thanks in advance......
            02-16-2024, 12:58 AM
