Well it looks like my last big laptop purchase has a bunch of bios locked ones. Other than my other Fujitsu question, I have over a dozen Hp 8470p laptops locked. I have tried several "tools" that are supposed to help after entering the password 3 times and get some code but no codes ever. I pulled the chip one one and read in hex editor but do not know where the password is located. Or if I download the HP bin file from HP and write that to it will that do it? New at doing this, TV chips were simple.
Hp 8470p bios password.
Re: Hp bios password.
https://www.badcaps.net/forum/showthread.php?t=79956
Use this to patch every bios file you read from those 8470p and then flash that file. -
Hi, I was taking a look at this post, how does the bin file work?
I actually have a 8470p that has bios password, but to be honest, i have no idea what im doing, i want to leave it whitout the battery cmos for a while to solve this.
I have tried using a tool thats on youtube where a guy uses a boot device, i did the procedure step by step but on black screen i never found the model of my computer.Comment
hello everyone salam to all.
i have a hp elitebook 8470 p bios password .
plz anyone unlock this..
file is attached.
Attached FilesComment
Channel: BIOS Requests ONLY!
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by iZakreHello everybody!
To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
The thing is that I had installed TeamViewer and could log into the computer... -
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
