Is at BIOS F21 do you have new one please?
HP Pavilion 17-e086nz s/n 5cd3494gvq
Every donation made will go towards server fees and maintenance costs. -
HP Pavilion 17-e086nz s/n 5cd3494gvq PID F6F60EA
But for bios chip contents i dont know how to do it.
Bios is not corrupted and laptop works well. I just wanted to update Bios
but HP remove all support for their old product. Maybe you know a site where
these old HP laptops drivers and bios are saved?
Thank you for your help.
17-E086SZ F24 biosHP Pavilion 17-e086nz s/n 5cd3494gvq PID F6F60EA
https://h30434.www3.hp.com/t5/Notebo...OS/m-p/9356310Attached FilesComment
by FalconPunchHello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...-
Channel: BIOS Requests ONLY!
by kt1998Hi, I'm try to fix corrupted bios HP Pavilion
S/N: 5CD0231RJC
ProdID: 8QN86PA#UUF...-
by macabookHello everyone,
07-24-2025, 02:17 PM -
I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
Symptoms:- Laptop powers on but no display at all (completely black screen)
- Caps Lock blinks twice with a pause, then repeats continuously
- F12 LED stays on permanently
- No POST, no boot sequence, nothing on screen
Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
What I've tried:- Hardware reset (battery removal, power
by TylerHyde21Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...-
- Loading...
