HP Pavilion 14-ce3015TU bios corrupted
  • kt1998
    • Aug 2024
    • 12
    Hi, I'm try to fix corrupted bios HP Pavilion
    S/N: 5CD0231RJC
    ProdID: 8QN86PA#UUF
  • peste
    • 13254
    • ROMANIA
    S/N: 5CD0231RJC
    ProdID: 8QN86PA#UUF
    bios extracted from HP website update for HP Pavilion - 14-ce3015tu
    DMI + KEYWIN 400000 - 40403F
    • FalconPunch
      Surface Pro X 1876 Bios corrupted
      by FalconPunch
      Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
      Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
      08-09-2025, 03:56 AM
    • macabook
      by macabook
      🧩 Initial Issue
      07-24-2025, 02:17 PM
    • sssssssssssssss
      Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
      by sssssssssssssss
      I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
      Symptoms:
      • Laptop powers on but no display at all (completely black screen)
      • Caps Lock blinks twice with a pause, then repeats continuously
      • F12 LED stays on permanently
      • No POST, no boot sequence, nothing on screen
      Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
      What I've tried:
      • Hardware reset (battery removal, power
      09-04-2025, 06:45 AM
    • TylerHyde21
      Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
      by TylerHyde21
      Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
      I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
      I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
      This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
      06-29-2024, 10:38 AM
    • Loli Popu
      DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
      by Loli Popu
      Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
      12-13-2024, 08:29 AM
