Bios for Lenovo ThinkPad X13 Yoga Gen 4
  • sergei66666
    • Mar 2022
    • 22
    • Russia
    Intel I5 - 1335U
    16 GB RAM
    Type 21F2
    ​Board LCFC KX3B0 KX3D1 NM-E812 Rev: 1.0
    Read from a working device.
    I unsoldered two large chips for reading.
    I read the third one without removing it from the board.
    I read each chip 3 times and the dumps matched (I didn't write the firmware to the chips again for checking).​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12413
    Originally posted by sergei66666
    Intel I5 - 1335U
    16 GB RAM
    Type 21F2
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • sergei66666
      • Mar 2022
      • 22
      • Russia
      Thank you. My fault.
      SN PF4JLR7H
      ps I didn't find this serial number in the dump, and there are no matches on the Lenovo website either.
      If I understood correctly, the serial number is stored in the EC
      • hoaca388
        Badcaps
        • Jan 2022
        • 12413
        SN PF4JLR7H
        X13 Yoga Gen 4_Type 21F2
        • sergei66666
          • Mar 2022
          • 22
          • Russia
          Thank you.
          p.s. For history. The dump from the first message is correct, it can also be used to restore your device.
          • ahmedalzenk
            • Oct 2019
            • 9
            • Deutschland
            hallo , i need bios file for lenovo x13 gen 4 21f3
            i readed the flash and restored again, now the laptop not woking, so i need original bios file with ME version to clean the me region , i got one here , but if i flash it, i got power led and charging led on one time them nothing,
            i think i need to clean me region , the version is 16.1.25.2049 , but is there no RGN on internet
            the best way is to get back up bios from the same laptop then clean me region
            thanks
            • shiyab
              • Sep 2023
              • 1646
              • india
              thanks
              post backup bios and snid
              • ahmedalzenk
                • Oct 2019
                • 9
                • Deutschland
                sergei66666 can u tel me how to restore the device ?
                i flashed it back , i have just power led and charging led on
                and no thing else
                  • 22097
                  and no thing else
                  Thread merged.. Type the laptop serial number, full name and model, motherboard model, etc.
                  post the contents of the bios chip even if it is corrupted..
                  read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                  • ahmedalzenk
                    • Oct 2019
                    • 9
                    • Deutschland
                    Lenovo x13 Yoga gen 4 , SN PF4VZYED
                    Bios w25q512JV
                    MB Number : KX3B0/KX3d1
                    NM-E812 REV: 1.0
                    Attached read bios using T056, with ISP and Socket
                    • ahmedalzenk
                      • Oct 2019
                      • 9
                      • Deutschland
                      the laptop was working before , it just has bios password , i wanted to delete the pass , but it look like i dont read the bios correct
                      • ahmedalzenk
                        • Oct 2019
                        • 9
                        • Deutschland
                        UPDATE
                        i flashed with the first one , i got lenovo logo , then search ME firmware then he can not recover ME
                        laptop restart and do it again
                        • sergei66666
                          • Mar 2022
                          • 22
                          • Russia
                          Hello!
                          If I understood correctly, there is an update for the ME region on the manufacturer's portal.
                          In the "Motherboard Devices" section, there is a file "Intel Management Engine Firmware for Windows 11", version 16.1.35.2557.
                          After unpacking, there are two files with the .cap extension.
                          Maybe someone can tell us how to extract the region from such a file?)
                          ps The unpacked region with this version is on the winraid.level1techs.com portal
                          • sergei66666
                            • Mar 2022
                            • 22
                            • Russia
                            I can't say for 100%, but it seems that in this laptop the password is stored inside the MEC1723N and at the moment the only option to reset the password is to replace this chip.
                            More about it:
                            1) https://www.badcaps.net/forum/troubl...nkpad-t14-gen2
                            2) https://www.badcaps.net/forum/troubl...-and-x13-gen-2
                            • ahmedalzenk
                              • Oct 2019
                              • 9
                              • Deutschland
                              Hello!
                              thanks for the answer,
                              do u mean , if i be able to extract the file , i get the laptop on , but with password , so if i delete me region , will be not help to delete the pass
                              so how to fix the problem with "unable to recover ME firmware"
                              thanks
                              • ahmedalzenk
                                • Oct 2019
                                • 9
                                • Deutschland
ID:	3697765Click image for larger version
                                • ahmedalzenk
                                  • Oct 2019
                                  • 9
                                  • Deutschland
                                  if u see the data sheet , we are able to unlock the pass , i think we just have to read it and set the Adress 0x40002c10 of 0xff , then we have unlocked the pass , i have i jtag at work , i try to read it with it then i give feedback
                                  • sergei66666
                                    • Mar 2022
                                    • 22
                                    • Russia
                                    thanks
                                    You can extract ME from update or download it from winraid.level1techs.com.
                                    I assume that after changing the ME region the password will remain.
                                    • sergei66666
                                      • Mar 2022
                                      • 22
                                      • Russia
                                      If it works via JTAG, that would be great. If I understand correctly, some have already tried, but it didn't work.
                                      If it doesn't work, then there are only two options (in my opinion):
                                      1) easier - replace the EC chip
                                      2) more difficult - edit the EC firmware so that it clears the memory block with the password. However, I don't know if the firmware is signed. It's possible that the modified firmware won't even start.
                                      • to5it0
                                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                        by to5it0
                                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                        I have opened the laptop and identified the main BIOS chip...
                                        10-24-2025, 01:35 AM
                                        Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        09-07-2024, 04:10 AM
                                        Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook X Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad ThinkPad X13 Yoga Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X13 Yoga Gen 2 (Intel) boardview and ThinkPad X13 Yoga Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                        09-07-2024, 05:00 AM
