need bin for Mac Air m2
  • Pingas
    expert
    • Jul 2020
    • 10
    • Brasil
    Hi friends, I need a bin dump from a mac 820-02862 256GB
    • 21467
    Post the macbook serial number.
    • Pingas
      expert
      • Jul 2020
      • 10
      • Brasil
      Hello, thank you for answering, here is the serial number: but before a question, the bin file can only be used on this machine, because the serial number is linked to the bin?
      DDQVJ3QV61
      • erkko13
        Thinkpad L390 Yoga (type 20NT serial R90VZWLN) BIOS2 dump needed
        by erkko13
        Ho ho ho, badcaps people,
        if this qualifies as bios request, hopefully. Actually BIOS2 for that laptop is second smaller SPI flash (Winbond W25Q80DVSNIG-GP-U), containing supposedly some config for TPS65988 which in turn manages USB-C stuff, including PD. This is possibly flash, where update "Power Delivery Firmware (TI TPS65988)" F407.06.29 -- https://download.lenovo.com/pccbbs/mobiles/r10pd10w.exe does its thing. Previous owner claims that after clean install of Windows 10 he installed thinkvantage tool of sort, which updated everything for that laptop. I did glance over...
        12-25-2024, 06:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • hyperwood
        [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
        by hyperwood
        I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
        The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
        I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
        āœ… What I need:
        • A working 2MB BIOS dump
        • Matching NM-E471 Rev. 2.0, e.g. JY575
        06-25-2025, 02:28 PM
      • Andreas_de
        Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
        by Andreas_de
        Hello!
        i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
        Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
        Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
        04-12-2025, 10:38 AM
