HP ENVY 2-in-1 15-fe0053dx Bios/TBT Charges at 5v
  • TheDando
    • Feb 2023
    • 32
    Hey guys I've been working on a HP ENVY 2-in-1 15-fe0053dx that had a dead EC chip. I've replaced the chip but the laptop only pulls 5v at 0.07amps.At this point I believe I need to reflash the Bios and possibly the TBT rom.
    Laptop Name: HP ENVY 2-in-1 15-fe0053dx
    Model : 15-fe0013dx
    Motherboard Model : JPR50 LA-M794P REV 1.0
    Serial : CND32207GZ
    ProdID : 7H9Y3UA#ABA
  • hoaca388
    Badcaps
    • Jan 2022
    • 12178
    Model : 15-fe0013dx
    Serial : CND32207GZ
    HP Envy x360 2-in-1 Laptop 15-fe0053dx (7H9Y3UA)
    I do not have TBT rom.
      • 21520
      Model : 15-fe0013dx
      Serial : CND32207GZ
      Will the laptop boot from the battery. The bios update from HP support has a a PD firmware update and also retimer firmware
      • TheDando
        • Feb 2023
        • 32
        No unfortunately it doesn't. I fear at this point I might have another hardware fault I need to track down.
          • 21520
          Did you flash the EC chip, was it blank or pre-programmed
          • TheDando
            • Feb 2023
            • 32
            It is a blank chip. I assumed that the laptop would program itself.
              • 21520
              I don`t know, you would need an EC programmer to read it, if it`s still blank then it would need programming.
              • Kenzi
                Cannot modify HP Envy 15 ep-00008na BIOS
                by Kenzi
                I'm trying to modify my BIOS to unlock the advanced menus and unlock the processor power limits. The first thing I have tried is reading the BIOS from the laptop and opening it up in amibcp, and changing the advanced menu to User. However, no matter what tiny change I make to the BIOS, when I flash it back to the laptop with a programmer it says there is corruption and the BIOS needs to be recovered.
                I've also tried rolling back the BIOS to an older version. I made the mistake of updating to the latest version and now I cannot even edit the CFG and OC...
                11-09-2023, 05:22 AM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • mizzed
                Bios Request - Dell Precision 5530 2in1 LA-F211P rev 1.0 - updated
                by mizzed
                Hi, Would anyone have a bios dump for a Dell Precision 5530 2in1 LA-F211P rev 1.0.
                Following a failed bios, I had a new bios chip programmed with the the XPS 15 9575 2in1 LA-F211P rev 1.0, which the motherboard has identical model numbers, (having not being able to find a 5530 2in1 bios) however both in bios and os, the Vega graphics, and sound boards are not detected or installable, everything else worked fine. The only difference I can see is that although the motherboards are nearly identical is that they have slightly different CPU/GPU 8705g vs 8706g.
                If anyone...
                01-05-2023, 06:53 AM
                by Vesko356
                08-11-2023, 03:27 AM
              • AustinCER
                HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
                by AustinCER
                I currently have an HP ENVY Desktop TE01-1214
                S/N -
                2MO22342GX
                Motherboard - L75365-001
                BIOS Chip - W25Q128JVSQ
                Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
                Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
                04-25-2025, 05:56 PM
