HP Laptop 15-dy****** BIOS Reflash
  • tigertec
    • Sep 2023
    • 16
    Hello all, I am pretty sure my BIOS is corrupt and I need to reflash. I have the chip desoldered and ready to go, however, I can't seem to find the file to do so. I was curious if y'all can point me in the right direction or perhaps provide the file.
    Thanks!
    Model 15-DY4013DX
    Serial 5CD244G3LS
  • Ponto da Manutenção
    • May 2024
    • 99
    • Brasil
    Serial number is not correct.
    Did you make a backup of the original bios?
    • peste
      • Dec 2016
      • 13433
      • ROMANIA
      Thanks!
      Model 15-DY4013DX
      Serial 5CD244G3LS
      post motherboard model, product number,etc.
      post the contents of the bios chip even if it is corrupted..
      • tigertec
        • Sep 2023
        • 16
        Here is the BIOS contents of the chip
        Board: DA0P5HMB8J0 REV J
        The model and serial are as stated above, those are coming off the back cover of the computer
        • peste
          • Dec 2016
          • 13433
          • ROMANIA
          The bios you posted is corrupt, and longer....it should be 16MB...or else it has 32MB...
          The bios chip must be unsoldered from the board before writing or reading..
          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
          solder wires between the programmer and the bios chip..
          here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
          read the correct chip and post again...
          • mydayparade
            • Jan 2021
            • 27
            • philippines
            this my laptop bios i uploaded it.
            my bios got corrupted laptop no power.
            help me to clean it thank you
              • 21679
              Type the laptop serial number, full name and model, motherboard model, etc.
              read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
              • mydayparade
                • Jan 2021
                • 27
                • philippines
                MODEL hp 15-DY2073DX
                Serial No.: 5CD3307073
                • mydayparade
                  • Jan 2021
                  • 27
                  • philippines
                  hello help me to clean this bios
                  • peste
                    • Dec 2016
                    • 13433
                    • ROMANIA
                    you have everything you need at post #5...087FD
                    https://www.badcaps.net/forum/troubl...ighlight=087FD
                    • Sebastian Codrean
                      BIOS file for ASUS F542UN laptop
                      by Sebastian Codrean
                      Hello to all of you! I need help with a BIOS file.
                      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                      02-20-2025, 10:25 AM
                    • EbrahimSiami
                      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                      by EbrahimSiami
                      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                      **What I have tried so far:**
                      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                      07-02-2025, 02:31 PM
                    • JoWed
                      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                      by JoWed
                      Hello Community,
                      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                      07-01-2025, 09:32 AM
                    • m1ch43lzm
                      Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                      by m1ch43lzm
                      Hi everyone
                      I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                      Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                      Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                      There's also an extra OTP Secu.R...
                      09-06-2025, 05:47 PM
                    • iZakre
                      HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                      by iZakre
                      Hello everybody!
                      To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                      The thing is that I had installed TeamViewer and could log into the computer...
                      02-19-2023, 02:27 PM
