1f5a e6400 solved!
    1f5a e6400 solved!
    HELLO! I've got solution for 1F5A bios to override master password.
    You have to downgrade bios to A14 using this method:
    use E6400A14.exe BIOS and with CMD line in windows create .HDR file "E4300A06.exe /writehdrfile"
    now the file E6400A14.hdr copy to pendrive.
    Take battery and power cord out, plug in usb.
    Hold END while you plug in power cord and release END when battery LED light start.
    If battery LED light blinks red/blue it should be flashing - wait till laptop restart.
    Now you have A14 BIOS and 1F5A change to 2A7B and online generator works for me.
    Type password, hold RIGHT CTRL, then ENTER.
    Try different USB ports and PENDRIVES.
    http://www.dell.com/support/home/us/...driverid=K4H02
    Re: 1f5a e6400 solved!
    Of course command to create HDR file should be "E6400A14.EXE /writehdrfile" sorry for mistake.
      unfortunately the BIOS file is no longer available on Dell site..
        Did you google the file?
        I found it on dell ftp site in 10 sec.
        Sorry but if you dont kniw how to do that I doubt you'll manage to unlock your notebook.
          Hello
          I've bought 2 Latitude E6400 on eBay. They arrived totally locked.
          I can't boot from HDD/CD/USB nor downgrade BIOS.
          Please can anyone help me to unlock my laptops?
          Service tags:
          742X1M1-1F5A
          19Q84L1-1F5A
            Originally posted by kooker1 View Post
            Hello
            Service tags:
            742X1M1-1F5A
            19Q84L1-1F5A
            You should try disconnecting the hdd before doing this.
            Here you go Dell still has the bios page running.
            Here's the link http://www.dell.com/support/home/us/...driverId=K4H02
            Just follow the instructions posted previously.
            IF YOU DON'T HAVE WINDOWS FOLLOW this post.
            http://honestpchelp.com/2015/downgra...00d630-series/
            ADMIN IF YOU SEE THIS PLEASE DON'T DELETE THIS MESSAGE AS IT MAY HELP MANY WHO HAVE BEEN SUFFERING.
              I would really appreciate if someone could help me with this one.
              I would like to set it up and change the boot sequence
              BIOS A16
              Service Tag : C3MQRM1-1F5A
              It's a Dell E6410
              Thanks in advance !
                Great job, thanks for sharing
                  I am trying to remove a -1F5A password from a Dell Latitude E4310 by downgrading the A11 BIOS to A09. I can download the BIOS .exe (E4310A09.EXE) file from Dell and copy it to the root directory of the laptop loaded with Windows 7. From the CMD prompt I can navigate to the root directory. However on executing the command E4310A09.EXE /writehdrfile I get a message "Invalid Command Line". My DOS is a bit rusty so I must be missing something. I have also tried this by booting from a USB and executing the above command directly in DOS, but nothing happens. I still don't extract the .HDR file. Has anyone got any ideas?
                    what is supposed to happen during the period where battery led flashes? any screen prompts? how long does it take? I see led flash power button light and hear fan running, screen is dark. tried 4 diff flash drives and ports.
                      Re: 1f5a e6410
                      hello friends i have dell 6410 latop bios password
                      how can i remove password
                      serices tag-9CLRMN1-1F5A
                      THANKS IN ADVANCE
                        i tried this method and worked with me
                        thank you
                          J2NJMN1-1f5a dell precision locked to bios admin , help
                          if possible for a bios dump so i can program new bios and replace
                          many thanks in advance
                            please help.......dell e5500
                            #GR3H94J-1F5A
                              #GR3H94J-1F5A
                              Try this :
                                Originally posted by jiroy View Post
                                Try this :
                                - Is your mean "reset bios by jumper"?
                                - I searched in your post document but still no answer. Can you tell us more, thank you.
                                  I have M4500 with A09 bios so do I still need to change the bios? I do have the 1F5A and none of the generated passwords work.
                                    Dell latitude e6410
                                    fpkf0p1-1f5a
                                    please help
                                      have you tried https://bios-pw.org/
                                        Hello!
                                        I buy Dell e6400, but now have some problem.
                                        I need administrator password for change bios setting.
                                        #4B2FNM1-1F5A.
                                        Please help!
